Cat p*ss removal
Old May 14, 2013 | 11:45 AM
STeve's Avatar
Super Moderator
Default Cat p*ss removal
Got to be one of the worst smells ever, what products if any can neutralise its odour as took a cat to vets who decided to relieve itself in the car
Old May 14, 2013 | 06:08 PM
v man's Avatar
v man
Zee Germans are coming
Get the dog to piss over it
Wet vac is the best option Steve
10 pound to the polish and they will sort it
Old May 14, 2013 | 06:11 PM
STeve's Avatar
Super Moderator
tried all the wives tales tricks but still can smell it, will have to hire one out of morrisons me thinks, cheers mate
Old May 14, 2013 | 06:17 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
buy a new car
Old May 14, 2013 | 06:54 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
IF you can get the carpet out then DO so, it'll have seeped into the underlay...then when you wet extract it'll just keep pulling the piss through.
Plus you'll more than likely lob water on an flood the floor below...
Take it out, short term loss.......................
it wont vanish quick esp if its pour homme la Tomcat as its very acidic hence it stinks..hope he drinks well as like us our piss reeks when we dont drink enough, plus he has shag glads involved
you need to kill the acididity,and ammonia.
I hate my career life real tears
Anyways Then clean carpet using your chosen carpet shampoo "LOW FOAM" and a STRONG industrial odour eater(below) mixed in with it, dont be shy neither.
http://www.amtechuk.co.uk/shop/CFR_D...o-pid-227.html
Ideally it needs to dry outside in a good frost that'll kill it off, DONT wap the heating up makes it worse just get AIR in.
then regular misting or light extraction using the chem above, say once a week when you clean car...
If it was vomit you'd be proppa fcuked
Erradication takes time...Masking takes minutes and lasts so
Good luck
Old May 14, 2013 | 06:56 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I did cat piss removal a few weeks ago,she didnt call back after a week so the smell must have gone!
I always tell them to call back if the smell comes back and i will go over it again.
Fraggle...'s Avatar
Fraggle...
On a tangent
hahahaha love it
Old May 14, 2013 | 06:58 PM
STeve's Avatar
Super Moderator
cheers for the heads up , the cat was boxed up and then seatbelted on the front seat, scrubbed it right away with baby wipes but I know as it drys the smell will increases hence asking as I have tried the vinegar trick too
Old May 14, 2013 | 07:08 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
U Should have put it in the boot, problem solved, and ahead of schedule
If it front seat then again it needs to dry fully if its been a while"before" you start to clean, if its still wet, crack on but DONT go heavy with the water mix, the water will trap the odour as it stagnates.
Draw out as much of the piss as possible first,,then clean.
Remember one mist coat = 3 draw out passes
Old May 14, 2013 | 07:12 PM
STeve's Avatar
Super Moderator
top man for the advice as I was tempted to just buy another interior for my little fez earlier, interior is mint so that idea was shelved
Old May 14, 2013 | 07:25 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
No worries, sometimes being at the bottom of the food chain has its uses
Like i say NO guarantee's but its do-able..just takes time, at worst you'll have to re-foam the seat,(£10 lol) personally id get the seat out as much as poss, air the shit outta it..
If it were FEMCAT wee no biggie, but tom dong juice is another level
Anyways good luck fella
Old May 14, 2013 | 08:09 PM
STeve's Avatar
Super Moderator
it was nutless young tom btw
Old May 15, 2013 | 07:01 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I would do the opposite, soak the seat with a apc and water mix so its soaks right into the foam then draw it out with a machine,do this several times
Then soak the seat with bio brisk so it goes into the foam and leave it
If the smell comes back repeat.
Old Jul 17, 2013 | 08:21 PM
vmackie's Avatar
vmackie
You could try some of the products specifically designed to deal with the problem such as ' 'Urine Off' or similar (seriously). Try a search on ebay.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Orion_Gav
Sep 29, 2015 04:50 PM
