mould stains
Old Jan 21, 2013 | 08:44 PM
cossie.087's Avatar
cossie.087
Default mould stains
as above whats the best way to remove the stains from car seats thanks cossie.087.
Old Jan 21, 2013 | 08:46 PM
doga-ot's Avatar
doga-ot
Nothing mate,depends how bad it is and if its on white stuff then it fooked. If its only light mould (not on white stuff) then leave to soak in with some detergent then after hor wash on high temp
Old Jan 21, 2013 | 08:53 PM
cossie.087's Avatar
cossie.087
the seats were a grey colour and the mould was pretty old i got rid of most of it with wet vac and steamer but cant get rid of the little spots left behind.
Old Jan 21, 2013 | 08:54 PM
doga-ot's Avatar
doga-ot
they prob wont budge then fella
Old Jan 21, 2013 | 08:59 PM
cossie.087's Avatar
cossie.087
its looking that way thanks anyway doga-ot.
Old Jan 24, 2013 | 10:13 AM
minder's Avatar
minder
if you got the use of a wet/dry cleaner mate the mould will definitely come out i do valeting for a living mate so i know what i am talking about if not any good valeter will be able to clean them for you
BEFORE PICS
AFTER PICS
Old Jan 24, 2013 | 10:46 AM
RichieST's Avatar
RichieST
A wet vac with hot water and some biologial washing powder should do the trick!
Old Jan 24, 2013 | 09:31 PM
cossie.087's Avatar
cossie.087
BEFORE PICS
AFTER PICS
thanks for the help guys,i use a vax multivac wet and dry vac with there own solution what do ye guys use dont know if i can use hot water but will defently try the washing power.
Old Jan 25, 2013 | 05:50 AM
RichieST's Avatar
RichieST
I've got a mini wet vac machine, always use hot and washing powder. Just don't use too much powder, make sure it all dissolves. Or the other way you could do it is mix it up in a bowl, scrub it into the seats with a stiff brush then use the vax just to extract it. Might not work as well though!
Old Jan 28, 2013 | 03:31 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Stiff brush to scrub and something like bio brisk in the machine works well.
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Tank Mike
Sep 14, 2015 03:56 PM
3drRich
Sep 13, 2015 07:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
Vincereese
Sep 3, 2015 12:49 PM
