Clay bars.
Old Sep 5, 2010 | 04:39 PM
Default Clay bars.
I got the auto glym clay bar kit for xmas last year and i decided to use it the past few weeks on my car and the wifes car. My cossie was painted last year and there wasnt really alot of dirt in the paint. I did the wifes fiesta today and i couldnt believe the dirt that the clay bar brought out of the paint. The dirt was like a brown colour. It took a few hours to do the whole car. I would reckonmend a clay bar kit to anyone. I would put some pics up if i had proper broadband.
Old Sep 5, 2010 | 05:06 PM
mr_joe0606's Avatar
mr_joe0606
it does make a difference i did mine last weekend was amazed when i looked at the clay.
joe
Old Sep 5, 2010 | 09:54 PM
BM08's Avatar
BM08
The only reason i put off doing the Honda is because when ive done it i know ive got to break my arm putting polish etc back on to protect it
Old Sep 5, 2010 | 10:03 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
whats this clay bar then havent heard of it? is it easy to do? can it go wrong and damage the paint ect?
Old Sep 5, 2010 | 10:52 PM
Moonstone Mo's Avatar
Moonstone Mo
Not really mate,you can get a mild and agressive clay..but having said that i have seen some shocking marring that people have inflicted.
go easy and make sure you use a fair bit of lubricant.
Old Sep 5, 2010 | 11:13 PM
Fiddy's Avatar
Fiddy
ill have to bring the mondingo round one day mate, and we'll set about it
Old Sep 6, 2010 | 12:58 AM
capricougar's Avatar
capricougar
used it on sierras. and gets regular use on coog! takes out al the grime, just love the feel of the paint work after use!
Old Sep 6, 2010 | 09:07 AM
matts1's Avatar
matts1
Easy to use, keep it lubricated and you wont mess it up, the added bonus is that
a) your not polishing grime into your paint once clayed as the grime is gone
b) your paint will feel silky smooth and polishing is then made easier as there is less friction from grime etc, so less elbow work.
I used the meguires kit that comes with the bar and the detailing lube spray for under £20.
Youtube is full of vids to give you some tips. My main tip would be to keep a good hold of the clay bar when using as it is easy to let it slip from your hand and you wont want to be using a bar that has hit the floor on your paintwork.
I also use things like tar spot remover first, you dont have to but I prefer to remove as much shite before I use the clay bar.
Old Sep 6, 2010 | 09:45 AM
Viper_'s Avatar
Viper_
^^ Good advice above
Claying is one of, if not the most beneficial part of doing a proper routine as everything that comes after it - the polishing, waxing and all subsequent washing, you'll get so much better results and more from the products when they're going over a properly clean surface. Doesn't need doing very often at all, so worth it imo.
Plenty of lubricant is the key as said as usually when someone drops the clay on the ground, it's due to the bar suddenly hitting a dry bit of paintwork and 'grabbing' at it - it then pulls it out of your grip. A little tip I like to do with the bar is after moulding it into a disc, form a little bar on the top surface that you can grip between 2 fingers so you've got more of a hold on it. Also check the surface regularly and refold it, especially when doing the lower half of the doors etc. as it can soon get pretty grubby and you want to be using a clean face to the clay wherever possible.
Old Sep 6, 2010 | 10:07 AM
Yeh they are easy to use. I just used water for the jub and it seemed to work. Fiddy will have to do urs one day but ive got a funny feeling it will take along time. Get one bought fella and we will do it. Ive only got a bit of mine left now.
Old Sep 6, 2010 | 10:11 AM
Fiddy's Avatar
Fiddy
if its like everything else on my car mate, ne doubt it will take a while lol.
aye ill get one bought mush
Old Sep 6, 2010 | 10:36 AM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
got to love the clay bars a mate also for great results use 90% caranuba wax its like molding clay and it is a one time application hard to work off but as u have all stateted well worth the effort
What is Carnauba Wax?
Carnauba wax comes from the leaves of a plant native to Brazil, the carnauba palm or Copernicia Prunifera to give it it's real name. The wax is obtained by processing the leaves of the plant, it will then be refined and bleached. The wax is not actually the leaves of the plant but an excretion from the leaves.
Carnauba wax is used in a variety of products including, shoe polish, cosmetics, surfboard wax and also in the food industry as a coating on chewing gum and of course in our beloved car wax.
In it's raw form carnauba wax is very, very hard, it is said to be as hard as concrete. A bar of pure carnauba is so hard and brittle it will smash if dropped on the floor. To make Rubbsih Boy's Original edition I use a carnauba wax that is in flake form. The blocks of wax are broken up into flakes, this makes melting far easier.
To be used in a car wax carnauba has to be softened and kept under control. This can be achieved using other waxes, such as Beeswax, and oils, such as coconut oil, all heated up and blended together.
A lot of car wax manufacturers quote high percentages of carnauba wax in their formulae, 70%, 80% some even 100%, how can this be true you may be wondering? Well it can't is the answer. Often when a manufacturer quotes the percentage of carnauba in their product they are referring to the wax content in their product not the total product. Suppose a wax is claimed to contain 70% carnauba, so 70% carnauba and 30% beeswax say = 100% total wax content, this could actually be a very small percentage of the final product, especially where thin liquid or spray waxes are concerned as they will mainly be water.
Old Sep 7, 2010 | 06:07 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
http://www.camskill.co.uk/products.p...19p10097&rs=gb this ok i might treat the saph?
Old Sep 7, 2010 | 11:36 AM
ive also got the auto glym hd wax which is brill too.
Old Sep 7, 2010 | 11:38 AM
Originally Posted by scottyrs
Cant go wrong for 20 quid i might even treat myself.
Old Oct 2, 2010 | 11:09 AM
Blunt.RS's Avatar
Blunt.RS
Dont buy the meguiars replacement clay bar
i got 1 at national day didnt realise till i got home it was only 1 bar for £9.99 what a joke
complete smooth surface clay kit which inc 2 bars £20
Old Oct 2, 2010 | 12:04 PM
ltd st200's Avatar
ltd st200
i used cleanyourcar.com own one and there good and a reasonable price. when i got the mondy and done it for the first time, cant belive how much come off.
Old Oct 2, 2010 | 05:39 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
Use a BH regular clay bar, its big enough to do around 3-4 cars easily and its designed to use just water for lubrication so is also very cost effective due to not needing a specific clay lube or quick detailer, you can even use some of your wash solution inside a spray bottle for added slickness across the paintwork.
Dave.
Old Oct 2, 2010 | 08:50 PM
Gavin E-Cos's Avatar
Gavin E-Cos
I also use Meguiars,
http://meguiars.co.uk/product/194
this kit is best IMHO, http://meguiars.co.uk/product/194 comes with a very thick microfiber cloth.
Old Oct 4, 2010 | 09:52 AM
Rsmat's Avatar
Rsmat
+1
Old Oct 20, 2010 | 07:42 AM
jonusb4's Avatar
jonusb4
Hundreds of years ago in what is new york asian escort now Great Britain and Northern France,lived the Celts.The Celts believed in new york asian escorts many gods,with the sun god as their favourite.They thought that it was"he"who new york escort ordered them what to do for their work and when they could rest,and"he"made the new york escorts earth beautiful and the crops grow.
Old Oct 20, 2010 | 05:04 PM
capricougar
^^^^^^^^^^^^^^^^^^WTF???? god botherer...
IainRS1700T
Sep 25, 2015 06:44 AM
mint_s2
Sep 2, 2015 08:58 AM
RSPTG
Fitness / Weight Training Discussions
35
Mar 2, 2012 08:01 PM
CraigoScott
May 12, 2007 04:15 AM
Dan
Concours d'élégance.
Jun 7, 2006 06:13 PM
