Over-spray
Old May 4, 2010 | 06:47 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Wax oil, Ive used Autoglym tar remover and,
Ive used G3 rubbing compound to remove overspray.
Old May 4, 2010 | 07:12 PM
Steve the Plumber
Have a look here,
http://shop.ebay.co.uk/i.html?_nkw=r...osacat=0&bkBtn=
Nothing to do with me.
Old May 4, 2010 | 08:20 PM
H7 CYA's Avatar
H7 CYA
No joy with a clay bar?
Old May 10, 2010 | 10:20 AM
EADetailing's Avatar
EADetailing
Sounds like you need a more agressive claybar?
Also for removing underseal use autosmart tardis(tar and glue remover)
Spray on and watch it run off(wipe it with a microfibre though) lol
Old May 10, 2010 | 10:49 AM
fiestamad's Avatar
fiestamad
g3 will do it halford sell it
Old May 10, 2010 | 10:52 AM
EADetailing
G3 will rub it in causing light swirling like when you wash with a sponge
You do not want to rub it in you want to lift it of the clearcoat,then again this is my job so i care about paintwork, this lad may not
Old May 10, 2010 | 12:09 PM
EADetailing
Originally Posted by S1 JOHN S1
What would you use then dude?
For the over-spray sonus orange clay(quite aggressive)
or
3M clay,again aggressive but will or the other will do it!
Wax-oil, autosmart tardis(its a tar and glue remover)spray on leave for a few minutes and wipe with a microfibre
Old May 10, 2010 | 03:29 PM
EADetailing
Thank's matey shall investigate .
Autoglym stuff is actually spary on wipe off too bloody strong stuff i'll give it that
No problem buddy,i do this for a job so ive experienced it quite a bit
Autoglym isnt bad but i find it needs a good few sprays to remove tar,wax-oil,good luck removing it
roy
Old May 10, 2010 | 03:33 PM
phatford's Avatar
phatford
spray white back over it pal
halfords sell good paints
Old May 10, 2010 | 06:21 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
will claybar get rid of the swirling that g3 leaves?
Old May 10, 2010 | 06:39 PM
andy130's Avatar
andy130
nope, needs polished with g10/3m
Old May 10, 2010 | 07:57 PM
Ebonycossie4x4
Damn, That means i need a machine doesn't it?
Old May 11, 2010 | 12:42 AM
Stevie-Boy's Avatar
Stevie-Boy
Gettin There
If it's not a large area you can correct it by hand but always easier with a Rotary or DA.
Old May 11, 2010 | 06:15 AM
EADetailing
Unfortunately it wont mate! The intention of a claybar is to lift contaminants a hand wash wont remove,i suggest washing your car as normal,get a food bag put over your index finger running along paint gently,then try it with no food bag,the bag increases the sensitivity in your finger so to check all contaminants are gone use a food bag
Removing swirls by hand is a stupidly long process,its ok if its your own vehicle,but for somebody like me doing this as a job it has to be done by machine,and id recommend you look into menzerna or britemax compounds,g3 is ok but there are far better compounds out there! Menzerna is designed for hard paints though,ford is known to be on the softish side,i wouldn't recommend anybody attacking scratches without a PTG (paint depth gauge) Striking through the paint will result in a paintjob,defeating the purpose off trying the job yourself,id highly recommend a PD8(paint detective8)
Old May 16, 2010 | 02:06 AM
GHAFRS's Avatar
GHAFRS
RSCRAZZY
machine polishing is prob by far the best if you know how to use it you dont get swirls or any other marks it more takes away the slight defects in the paint as you can see
Old May 17, 2010 | 02:35 PM
Ebonycossie4x4
its dark cars that are the issue, well thats what i have found so far.
Shows up marks and swirls so easily.
Old May 17, 2010 | 09:14 PM
H7 CYA's Avatar
H7 CYA
Looks cracking mate
Cragrat
21
Jun 10, 2012 09:55 AM
S1 JOHN S1
May 17, 2010 08:52 PM
CraigJ
Jun 16, 2008 06:43 PM
