marks after using mop
Old Jun 2, 2009 | 11:44 AM
andy130's Avatar
andy130
Default marks after using mop
marks are of the pad going over and back if u no what i mean?
what causes them?
cheers andy
Old Jun 2, 2009 | 03:12 PM
Viper_'s Avatar
Viper_
I'll assume you mean buffer trails here, and it's usually moving the polisher too quickly over the area you're working on and not giving the abrasives sufficient time to break down properly.
Any chance of a pic so that it can be diagnosed a bit more accurately?
What kit were you using?
Old Jun 2, 2009 | 03:53 PM
boost mad's Avatar
boost mad
As Mr. viper said. It will either be buffer trails or maybe even pig tails if something has got caught under the pad
Old Jun 2, 2009 | 04:17 PM
andy130's Avatar
andy130
heres the prob
am using g3?
Old Jun 2, 2009 | 04:33 PM
3drpete's Avatar
3drpete
it mite be because the g3 is a tad course we used to go over it again by hand with a compound calld finesse its a bit of hard work but it used to get rid of alot of swirls
Old Jun 2, 2009 | 04:35 PM
andy130's Avatar
andy130
3m finesse?
Old Jun 2, 2009 | 07:06 PM
Rollin Rides's Avatar
Rollin Rides
Anyting forsale let me no
make sure you got a good mop head and not one thats worn out that dont help, also go over it carefully now as you would have cut quiet alot using the G3
Old Jun 2, 2009 | 07:26 PM
smudgerz's Avatar
smudgerz
All you need to do mate is get a soft waffle head and some 3m fine cut compound or 3m ultra finna (sp!) and go over it again with your mop on a slower speed. Job done.
Smudge
Old Jun 3, 2009 | 08:03 AM
boost mad's Avatar
boost mad
Thats marring, although its called a few different things.
Its where the compound hasnt been worked for long enough for it to "polish" after its done its cutting work. OR, its where the pad and compound choice are to aggressive for the paint.
Either way, it just needs finishing with a less aggressive pad and compound combo
HTH
Old Jun 3, 2009 | 05:30 PM
Gav Diamond's Avatar
Gav Diamond
As above.
I believe G3 is a constant abrasive, ie: the abrasives do not deminish down. It is also a very harsh compound and as such you will need to go over the paint again with a less abrasive polish.
Start with a finishing polish and if this does not remove the marks something more abrasive will be needed then again with the finishing polish and that will come up like a mirror.
Old Jun 5, 2009 | 07:18 PM
Polished Bliss's Avatar
Polished Bliss
Official Car Care Sponsor
To add to the above, what you can see if hologramming, caused by using a coarse abrasive at high speed without finishing down properly. To remove it, polish the panel again using a very fine finishing polish and a soft finishing pad. Also, you need to use the zenith method - start off spreading the polish at 900rpm, then up the speed to 1500rpm to work the polish and break it down, then finish off with half a dozen passes at 900rpm and zero pressure to refine the finish. Should get you a far, far better result. A great finishing polish for Ford paint is Menzerna 85RE, applied using either a 3M Finishing Pad or a Menzerna Finishing Pad.
Old Jun 6, 2009 | 09:06 PM
3drpete's Avatar
3drpete
thats what i was thinking lol
Mark RS
Mar 5, 2021 06:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
