Belkin wireless router help pleaseee
Old Nov 28, 2005 | 08:11 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Default Belkin wireless router help pleaseee
I bought a belkin wireless router as i was told its easy to set up But its not Ok 1st of all i put the i.p in given and straight away i worked out how to get on the net
But i couldnt get my laptop on the net so i rang the helpline and without sounding racist they were from india or somewere and i couldnt understand him at all
So i got as far as a little icon on my laptop in the right corner that says connected so i thought it was ok but i type in a web address and it says access denied
Anyone know were i've gone wrong, cheers ben
Old Nov 28, 2005 | 11:11 PM
ronf42's Avatar
ronf42
try this ,
click control panel
then network connections
belkin icon
properties
configure
then ad hoc channel
value 804.11b/g
then try the scroll down bar with numbers 1- 13
try each number and then connect to see if it will do so
my connection is on 4
hope this helps
Old Nov 28, 2005 | 11:30 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Ok i will have a look now cheers mate Do i do this on the laptop or computer
Old Nov 29, 2005 | 07:31 AM
DanRSturbo's Avatar
DanRSturbo
Do that on the laptop, have you set up the wireless connection ? Set both computers on the same network ?
Does your ISP assign you a static ip address then ?
Old Nov 29, 2005 | 05:26 PM
Benni's Avatar
Benni
Ban[B][/B]ned
I dunno what any of that means And i cant understand them on the helpline I have a connection on the laptop as it says i do but it says access denied
Old Nov 30, 2005 | 08:17 PM
DanRSturbo's Avatar
DanRSturbo
Is it a wireless connection on the laptop ?
Old Nov 30, 2005 | 09:55 PM
Benni's Avatar
Benni
Ban[B][/B]ned
I have a wireless card into the side of the laptop which came with the router and the router connected to my pc which is working as my internet now. Evertything is flashing to tell me its all working but its not
Old Dec 1, 2005 | 08:42 PM
DanRSturbo's Avatar
DanRSturbo
Right,
Who's your internet providor ??
Have you actually set up the wireless network on the pc that has the router ?
Old Dec 3, 2005 | 09:48 PM
MikeyXR2i's Avatar
MikeyXR2i
Mine is setup as follows, Belkin wireless ADSL router connected to phone line, RJ45 network cable from router to PC, then i got a laptop running a Belkin Wireless card. For some reason the belkin router doesn't like automatically setting up IP Addresses or windows trying to do it, so u need to set em manually.
Ip Addresses on the router are set in blocks to allow multiple systems to connect to it, i only wanted 2 systems networked so i only set two slots, for example, 136.148.4.1 for the first system
for the second to connect 136.148.4.2
For example On your first system set the first address IP Address to 136.148.4.1, then set the subnet mask: 255.255.255.0,
then the default Gateway, which will be the address you use to access the built in software of ya router, also use this address to set the DNS Server.
NathR
24
Jun 17, 2005 08:35 PM
Cossy Dave
Computers, Consoles and I.T.
Apr 27, 2005 06:23 PM
dvid
11
Jan 14, 2005 12:25 PM
Jim Galbally
Nov 10, 2004 11:33 AM
apples24
Jul 12, 2004 06:10 AM
