3 hard drives
Old Nov 9, 2005 | 09:44 AM
glen rs1800's Avatar
glen rs1800
Default 3 hard drives
I ve built my own computer (1st time novice)
But have now run out of hard drive space (massive mp3 collection!)
and wanted to add a 3rd hard drive i have space in the case but was not sure on the wiring?
hows it done?
Old Nov 9, 2005 | 11:37 AM
DanRSturbo's Avatar
DanRSturbo
Right, as standard you have 2 IDE channels on your motherboard. This can run a maximum of 4 drives.
If you look at my CD Drives, you'll see the cable runs direct from the motherboard, to the DVD-RW (bottom drive) then into my DVD Drive (top drive)
top drive is master, 2nd drive is slave, and that's it basically
HTH
Old Nov 9, 2005 | 12:17 PM
glen rs1800
so thats means i cant do it then as i have 2 dvd drives and 2 hard drives?
Old Nov 9, 2005 | 12:50 PM
EssexBoyRacer's Avatar
EssexBoyRacer
you will need an IDE controller card if you want to add any more devices, but make sure you have a power suppply up to the job and enough power connectors.
Old Nov 9, 2005 | 02:54 PM
DanRSturbo's Avatar
DanRSturbo
I have a maxtor PCi ide controller in my machine, it has 2 ide ports on it
which you can see in the bottom left corner of my case
Old Nov 9, 2005 | 02:56 PM
EssexBoyRacer
Dan you need to pop down to the pound shop and pick up a couple of packs of cable ties
Old Nov 9, 2005 | 03:47 PM
glen rs1800
IDE controller card sounds like the best idea then, i have a 500w Psu but no spare power conectors coming of it?
Can you by splitters for power to hard drive?
Old Nov 9, 2005 | 03:54 PM
EssexBoyRacer
yes you can buy spiltters. I dare say you will be ok with a 500w power supply. I am running 3 hard drives drives, 2 DVD drives and 5 fans with the standard power supply that came with my case.
Old Nov 9, 2005 | 06:03 PM
DanRSturbo's Avatar
DanRSturbo
These are what I have in my machine
http://www.ebuyer.com/customer/produ...duct_uid=57662
And this is all ebuyer list for hard drive controllers
http://www.ebuyer.com/customer/produ...ice&show=stock
Old Nov 9, 2005 | 09:57 PM
xpackcapri's Avatar
xpackcapri
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
tib2220
Sep 14, 2015 12:33 PM
