Problems accessing PF.......cry
Old Oct 26, 2005 | 07:48 PM
gurnE's Avatar
gurnE
Default Problems accessing PF.......cry
Soooo close to 4000 posts as well
Getting alot of problems accessing pf.
I'm getting the standard 'Page not displayed' thing after it tries to load pf for about 20 seconds
If I restart my router I get access from anywhere between 2 and 20 minutes
I've spoken to my ISP who say it's timing out after it has left them.
Can anyone please help
Here's the trace I'm getting
Old Oct 28, 2005 | 09:30 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Is it just PF it does it on???
Old Oct 28, 2005 | 09:48 AM
Jim Galbally's Avatar
Jim Galbally
"timing out lafter it's left them"
they mean you can't get outside THEM. ie it's THEIR problem
Old Oct 28, 2005 | 11:06 AM
AndyBlackFRST's Avatar
AndyBlackFRST
The IP addy takes you to
http://193.19.218.6
FastIron Edge 2402.
I guess this is your ISP.
If this isn't, then could be spywarre/Adware on your system re-directing your web addresses
Old Oct 28, 2005 | 11:14 AM
Poom's Avatar
Poom
Not sure but have your host files been edited?
Again a spyware problem could maybe cause it!
Old Oct 28, 2005 | 11:36 AM
gurnE's Avatar
gurnE
Hi Guy, thanks for your help
Yes, it's just Pf it does it on.
My ISP is Plus.net and according to them it's after it's left them
Who are Fastiron Edge then? Are they the problem?
Old Oct 28, 2005 | 11:51 AM
AndyBlackFRST
FastIron Edge is a switch.. Maybe this is at your ISP end.
Access through this seems to require usernames and passwords.. I assume you have a redirector app setup on your system.. Spyware/adware related.
Old Oct 28, 2005 | 12:21 PM
Jim Galbally
yes its after its left plus.net onto THEIR isp (yes ISPs have bigger ISPs)
the responsibility lies with plus.net to chase their ISP
Old Oct 28, 2005 | 12:50 PM
gurnE's Avatar
gurnE
Cheers Jim.
I've emailed them again
Old Oct 28, 2005 | 03:52 PM
gurnE's Avatar
gurnE
Right, they've come back with;
This is an unusual case.
If it was a problem at our end then i suspect that the site would not work at all, that it does show for 2/3 mins after a reboot suggests that the problem is more likely to be at your end unfortuantely.
Since you have a router there will be a built in firewall included with it, you may wish to check that or any logs it may have.
Also can you provide us with a tracert to the site when it is working?
Finally we can rule out your account as an issue with a dial test, this basically involves connecting as yourself so we'd need you to be offline at the time.
If you want us to do this then please specify a decent time window for us to test within, we have a night shift if this is more convenient for yourself.
I'll get them to do a dial test tomorrow.
They've asked me to provide a tracert when it's working. How do I get this as it dissapears when it connects?
Also, how do I check it's not my router?
Thanks again peeps
Old Oct 28, 2005 | 05:00 PM
Jim Galbally
how to check its not your router? common sense
you've done ight by doing a tracert, this proves its not your router
gingeRS
17
Oct 2, 2015 09:42 AM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
