lcd tv and pc input
Old Apr 28, 2008 | 05:31 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
Default lcd tv and pc input
i have just bought myself a 37 inch lcd tv that is now connected to my pc. All is good. On thing though, its a 1360x768 hd tv, but when i select this on my graphics card settings, it says not supported on the tv. It supports the res below that, but doesnt quite fit the screen right. I have it going through VGA atm, but would running it through the s video or hdmi be a better choice to make it work idealy. BTW the graphics card is a 8600 GT. Yes i know, they are apparently rubbish, but is more than capable fir watcing tv on and seeing the internet in a really nice res
Old Apr 28, 2008 | 05:47 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Try running the telly in 1440x900 in your gfx card settings, the telly should then detect its a HD source and reduce the size accordingly
Works on my Philips 50" Plasma
Old Apr 28, 2008 | 05:55 PM
Stephen_B's Avatar
Stephen_B
thats the res for my 19 inch monitor but it doesnt let me use that res for the tv
if i go on anything other than 1280x1024 then it says not supported on the tv
Old Apr 28, 2008 | 06:18 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Try 1280x768 as that will show as a HD resolution aswell.
Whats the resolution of the telly for HD, is it 780p/1080i/1080p etc etc?
Old Apr 28, 2008 | 06:27 PM
Stephen_B's Avatar
Stephen_B
im assuming 780 as it was really cheap for a 37
Old Apr 28, 2008 | 06:31 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Try 1280x768 then and that should work nicely
Old Apr 28, 2008 | 06:56 PM
Stephen_B's Avatar
Stephen_B
will give it a try once im back on the big screen again. Im currently back on my 19 so ican sit at my desk and listen to PHAT CHOONZ on my earphones
Old May 1, 2008 | 08:19 AM
Joris_FRST's Avatar
Joris_FRST
there's a simple trick to it.
In the nvidia software you have to set some changes as a custom resolution.
It's a case of puting 1360 / 768 as resolution, but put the timings for 1920x1080
If you don't know how to do this i'll attach some screenshots ?
Works fine here over DVI-HDMI with my philips LCD. (took some time to work it out)
Old May 1, 2008 | 09:54 AM
DanRSturbo's Avatar
DanRSturbo
It depends what the maximum settings are for on the pc input on the tv. Mines a max of 1280x1024 sxvg, haven't tried it on a dvi-hdmi connection yet.
Old May 1, 2008 | 11:27 AM
Stephen_B's Avatar
Stephen_B
well before i was running dual screen mode with the 19 inch monitor as thr primary. I am now just staying in single screen mode on the nvidia control settings, but just selecting the tv to use in the taskbar menu, and the picture is loads better. Perhaps the graphics card just cant hack 2 high res screens running at once?
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
martysmartie
Sep 6, 2015 10:22 AM
Bailes1992
Sep 3, 2015 02:17 PM
dojj
Aug 25, 2015 06:56 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
