High Running RAM....
Old Feb 6, 2008 | 12:58 PM
BillyCabrio's Avatar
BillyCabrio
Default High Running RAM....
I've noticed over the past few days that my RAM has been running at around the 50% mark, but today its constantly up around the 65-70% mark and it dosen't fluctuate
Any ideas why its so high? And what i can do to get it back down to the low 10's where it used to be?
Heres my system propities if thats any help?
http://img.photobucket.com/albums/06...mPropities.jpg
Old Feb 6, 2008 | 01:04 PM
BillyCabrio
You can see in the bar to the right hand side of the screen the dial showing the RAM running high.
Old Feb 6, 2008 | 01:36 PM
BM08's Avatar
BM08
Unless you can see its slowing down then i wouldnt worry, this is vista were talking about, it uses ALOT of ram.
Do you run many start up programmes? show me your task manager, control alt and delete
Old Feb 6, 2008 | 05:09 PM
BillyCabrio
What do you mean start up problems?
Its never been a problem up until recently
Old Feb 6, 2008 | 05:28 PM
BM08's Avatar
BM08
I said programmes not problems
I want to know what programmes you have running in the background, you might have loads of stuff you dont need and can be disabled, this will bring the ram usuage down
Old Feb 6, 2008 | 06:00 PM
BillyCabrio
Thats what i meant lol
what am i looking for to tell you what there is?
Old Feb 6, 2008 | 08:06 PM
BM08's Avatar
BM08
as above press control alt and delete and get task manager on the screen.
That will list everything running on the pc right now, maximize the window so i can see everything then take a screenshot.
To see what you have automatically loading up when you turn the pc on, click the start bar and type in "msconfig" in that little box at the bottom then you will see msconfig, click on that to open it, then click on the "startup" tab at the top and then take a screenie of this aswell and ill have a look
Old Feb 6, 2008 | 08:15 PM
BillyCabrio
Right heres the screen shot of the Task Master
http://img.photobucket.com/albums/06...askManager.jpg
The system properties page won't expand and theres a shit load on it
Old Feb 6, 2008 | 08:26 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
jesus how much ram is firefox using? Get rid of that shit!
Old Feb 6, 2008 | 08:28 PM
BillyCabrio
I know, i can't work it out either
Its only recently the RAM usage has shot up
Old Feb 6, 2008 | 09:45 PM
BM08's Avatar
BM08
firefox sometimes does use a silly amount, but ive got 2Gbs of ram on my pc and it doesnt slow down at all so i dont give a shit how much it uses, id rather have a browser that uses more ram if it means its better than I.E
Well i can tell you know 85 processes is very high, when i had vista i had about 45-50, and on xp now im running 36.
Half of them are not showing because you needed to click "show all", but already i can see one or two things you can remove like itunes.
What you can do is when your bored or have time google each one and it will tell you what it is and if you can remove it, takes time but if your pc runs better its worth it
Old Feb 6, 2008 | 09:51 PM
BM08's Avatar
BM08
oh my lord that not norton i can see is it
if so thats probably more than half your problem
you should be using this http://filehippo.com/download_avg_antivirus/
EDIT i only just realised you posted your pc specs above, thats a damn good pc there
Old Feb 6, 2008 | 10:13 PM
BillyCabrio
I knew that would leak your sex wee
Old Feb 6, 2008 | 11:54 PM
FastFordChris's Avatar
FastFordChris
mine will usually sit at around 30-38% with just the start up programs running and shoot up to about 42-45% with IE and wmp running (i have 2 gig ram) it maybe that norton or another program has run an update which has installed additional programs/drivers to your system.
it could also be that you may of picked up a few unwanted programs (adware etc) so i'd do a full system scan to be safe
if your using norton, just make sure your not paying for it
Old Feb 7, 2008 | 11:05 AM
BM08's Avatar
BM08
Honestly id uninstall norton and install AVG, ive never had one single problem in the year ive been using it, and my pc is on the internet every single day. That should free up some ram straight away.
Also remove some processes, because 85 is ALOT as i said lastnight.
dombanks
Sep 21, 2015 08:38 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
RSmark84
Sep 13, 2015 01:29 PM
Eigdoog
Sep 13, 2015 05:46 AM
