Computer help - fitting a second DVD-RW drive
Old Oct 27, 2007 | 09:08 AM
aksimmo's Avatar
aksimmo
Default Computer help - fitting a second DVD-RW drive
Hi all
I am getting an ex demo Compaq Presario PC with XP, an AMD Athlon 3500+ with 320GB HD (2 x 160) & 1GB RAM for £200.
It comes with a DVD-RW and spare expansion bay. On my current HP PC of the same design series but 2660 Celeron I had a second DVD-RW fitted so I can copy directly disc to disc instead of via the PC.
Fitting the second drive is easy enough but how do you tell the PC it has an extra drive as last time I tried the PC got confused and on the eject command would eject BOTH DVD trays!
I believe you have to make one a slave but not sure how?
Any help appreciated thanks.
Ash
Old Oct 27, 2007 | 09:58 PM
DanRSturbo's Avatar
DanRSturbo
On the back of the drive, there will be the jumper, a bit of plastic covering 2 pins. Simply remove and place the "jumper" to cover the 2 pins which will set the device as a slave.
Old Oct 27, 2007 | 11:15 PM
Alex_86's Avatar
Alex_86
you could also put the jumper to cable select.. then the cable would select for you as long they are on the same cable
usually the cd rom is at cable select from default
Old Oct 28, 2007 | 10:11 PM
aksimmo's Avatar
aksimmo
Many thanks - will try that when it arrives
BlakeMoyle
Sep 1, 2015 02:24 PM
cossynut2
Aug 19, 2015 11:29 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Sjieter
Aug 5, 2015 09:47 PM
