program
Old Aug 30, 2007 | 04:18 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default program
is there a program you can get that tells you whne the net has bee accessed and what sites they were on want to keep track of the comp when im out and is the programs to lock sites and otehr programs
Old Aug 30, 2007 | 06:00 PM
Alex_86's Avatar
Alex_86
yes it is, will find 1 later to you mate
, you could also look in the history for the internet browser to see where it has been
Old Aug 30, 2007 | 06:08 PM
djmillsy's Avatar
djmillsy
Fife Radge
i know about the history but i want to know of times on the net and lock site and programs
Old Aug 30, 2007 | 06:09 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
run the net connection through a proxy and check the logs is the easiest way, everything and anything running on the pc itself can be worked around
Old Aug 30, 2007 | 06:29 PM
djmillsy's Avatar
djmillsy
Fife Radge
how do i do that can work a few thi8ngs on the comp but dumb when it comes to that
Old Aug 30, 2007 | 09:37 PM
Turbocabbie
Top Cab !!
you would basically run the computers which access the internet through another computer specifically setup to act as a firewall / filtering system for these computers which will log all information going through it.
This way you can set rules to limit connectivity or services and log all internet activity. -- This is not 100% secure however its reasonably effective
Any filtering or log software that is dependent upon running on the system being filtered is very easy to get around
The Australia government for example spent $84 million dollars developing software for this purpose which was cracked within 30 minutes of going live
http://gizmodo.com/gadgets/porn-for-all!/australian-84-million-porn-filter-thwarted-by-16+year+old-293419.php
Its knowledge that will achieve what you wish to do, however your chances of successfully achieving that with Windows on its own and not running though a proxy server is slim as in reality it can not be locked down without reducing functionality.
With OSX or Linux you have a pretty good chance if you understand it
Old Aug 30, 2007 | 09:39 PM
Turbocabbie
Top Cab !!
Web proxy
Proxies that focus on WWW traffic are called web proxies. Many web proxies attempt to block offensive web content. Other web proxies reformat web pages for a specific purpose or audience (e.g. cell phones and PDAs or persons with disabilities)
Many organizations — including schools, corporations, and countries — use proxy servers to enforce acceptable network use policies (see content-control software) or to provide security, anti-malware and/or caching services. A traditional web proxy is not transparent to the client application, which must be configured to use the proxy (manually or with a configuration script). In some cases, where alternative means of connection to the Internet are available (e.g. a SOCKS server or NAT connection), the user may be able to avoid policy control by simply resetting the client configuration and bypassing the proxy. Furthermore administration of browser configuration can be a burden for network administrators.
Access control: Some proxy servers implement a logon requirement. In large organizations, authorized users must log on to gain access to the WWW. The organization can thus track usage to individuals.
http://en.wikipedia.org/wiki/Web_proxy
Old Aug 30, 2007 | 10:03 PM
djmillsy's Avatar
djmillsy
Fife Radge
i see is there a program that i can use to password other progs
Old Aug 31, 2007 | 08:07 AM
Alex_86's Avatar
Alex_86
believe its a child control prog you want
like this?
http://www.salfeld.com/software/childcontrol/index.html
add me to msn or something and i can send you a file
Old Aug 31, 2007 | 03:33 PM
djmillsy's Avatar
djmillsy
Fife Radge
not sure basically to lock programs so you need to put a password i to open them and is there a webpage blocker for firefox
Old Aug 31, 2007 | 07:54 PM
Turbocabbie
Top Cab !!
I would configure and define user groups and then restrict them using the registry as shown in the methods below
http://articles.techrepublic.com.com...1-5193303.html
http://www.pctools.com/guides/registry/detail/969/
You can also block website by configuring the hosts file such as the method shown below and then restrict any modification by users other than the Admin
http://www.mvps.org/winhelp2002/hosts.htm
for example an entry in the hosts file such as 127.0.0.1 passionford.com would block access to passionford
Using any application to restrict another application is pointless as it clearly shows what you have to attack to work around it
Iain Mac
Sep 13, 2015 09:16 PM
Bailes1992
Sep 3, 2015 02:17 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
