Wireless...
Old Jul 22, 2006 | 11:19 AM
adamS2RST's Avatar
adamS2RST
Default Wireless...
Currently moving home and previous occupants have left all their wireless hub etc and said to use it. I'd rather not have wires trailing about as I need to get two machines on the web in different locations in the house. So, is it as simple as buying a couple of wireless cards for the box's and making them see the wireless hub? I am currently on bt broadband (not wireless) is this going to make any difference, i.e it'll still work won't it?
What else do I need to know.
Old Jul 22, 2006 | 12:38 PM
DanRSturbo's Avatar
DanRSturbo
Basically, it'll depend on what wireless hub's they have left. But in a nutshell, if you have 2 x base units, just put a pci wireless adaptor in one of them, and connect the other one to the hub via ethernet cable
Old Jul 22, 2006 | 01:32 PM
adamS2RST's Avatar
adamS2RST
Dan, I forgot to mention that the phone line and wireless gear is all upstairs in a bedroom, not near where the machines need to go, and I want to avoid trailing an rj45 across the landing to the other room etc, but with the wireless hub do I still need to plug it in to one of the machines via usb to work?
Old Jul 22, 2006 | 08:19 PM
L33 BYT's Avatar
L33 BYT
Wireless should be fine from both machines without problems.
Wack a wireless adaptor in the machines set up WEP on the hub/access point so you neighbours cant use your BB to look at porn.
The only reason you may need to plug into it USB is to configure it. IE WEP.
Now depending on who set this up and what model it is you may not be able to access its setup console wirelessly. Mine has a check box to disable configuration via wireless.
The wireless side is all end user kit. Its still working on Ethernet/TCP-IP protocols so won't matter if its wired/wireless.
Old Jul 22, 2006 | 08:36 PM
Thrush's Avatar
Thrush
Irritating c........
I don't have wireless myself, but from talking to others about it, a proper wireless hub and modem shouldn't need to be connected directly to a machine to "put out" broadband. As with what Lee said tho, you might need to connect it via USB to a computer in order to configure it with your ISP details and set it to connect with your other machines. My suggestion is temporarily set up a PC (or better still use a laptop) plugged into the hub/modem via USB, configure it, and get it to connect to your machines. Then once you have everything set up, you should be able to unplug the laptop and it should run fine
Old Jul 22, 2006 | 09:02 PM
adamS2RST's Avatar
adamS2RST
Cheers guy's was pretty sure it would be fine Plugging in to configure will be fine...and yes I will be securing it don't worry
In fact....just looking into the wireless router it is either one of these:
http://www.shop.bt.com/invt/car103
http://www.shop.bt.com/invt/car104
It DOES seem though that they are designed to either work with BT Yahoo Broadband or BT Broadband. (I'm using BT Broadband) and I have a funny feeling this one is the Yahoo one (Box etc is at the other house)
So maybe it WONT work....fuck knows how it would be able to establish that and what the point of it is
Ad4m RST
Mar 28, 2015 02:16 PM
S2martin
Oct 27, 2007 11:00 PM
Thrush
Computers, Consoles and I.T.
17
Jun 23, 2007 06:00 PM
