Partitioning Hard drives?
Old May 19, 2006 | 12:08 PM
Thrush's Avatar
Thrush
Irritating c........
Default Partitioning Hard drives?
Hey guys, I just got my USB enclosure so I now have a 60gb portable HDD
I want to set up partitions on it, so that different computers (gonne be shaed between 2, maybe 3 PCs) have their own "space" on the HDD
How do I do this?
It's plugged in via USB BTW, not IDE slave
Old May 19, 2006 | 06:06 PM
Thrush's Avatar
Thrush
I swear I did it once, but I cannot figure how I did it lol....
Old May 19, 2006 | 06:38 PM
Andreas's Avatar
Andreas
If you are running XP start the administration tools and choose the icon with a computer on i t (ive a swedish version and don't know its english name. )
Then click on the dischandler and you should be able to partition your drive.
Old May 19, 2006 | 07:06 PM
Thrush's Avatar
Thrush
Ah! Thats right! Admin Tool, Comp Management, Disk Manager!
Thing is, I can't find an option to repartition the drive. I can delete the partition, or format the partition, but not re-partition (or add a partition)
I don't want to delete as it dissapeared from my system and I couldn't get it back for ages
Old May 19, 2006 | 07:13 PM
Andreas's Avatar
Andreas
Strange, but if you got one single partition now you would have to delete that and then create smaller partitons, one at a time. Ive never used USB-disc though so im not shure if it differs or not to internal drive.
Old May 20, 2006 | 02:29 AM
DanRSturbo's Avatar
DanRSturbo
You need to delete the partiotn, then create 2 or 3 small ones on the drive
Old May 20, 2006 | 04:56 PM
Thrush's Avatar
Thrush
Dan, I don't get how to do that tho! When I right clicked on J: (the USB HDD) and selected "DELETE" it said everything will be deleted, so I said fine. Then J: dissapeared!
I found it again in the Disk Management thingy listed as "DISK 5 - UNALLOCATED" and right clicked and went "FORMAT" and it assigned it a file path of J: again, but once thats done it is the full size again....
There was an option with somehting about PRIMARY PARTITION and EXTENDED PARTITION, but a quick read up on Google said that as a mass storage device, the computer won't "see" the extended partition...
Old May 21, 2006 | 09:11 PM
Andreas's Avatar
Andreas
You need to create smaller partitons ie not the full disk. Make a primary partition that dont take up all the disk space then you can create extended or whatever its called with rest of free space.
I dont remember the exact steps but never had a problem with it.
Old May 22, 2006 | 12:04 AM
Thrush's Avatar
Thrush
But if the PC can't see these extended partitions, then there's no point having em is there?
Old May 22, 2006 | 12:14 AM
DanRSturbo's Avatar
DanRSturbo
Use Partition Magic to do it
Old May 22, 2006 | 06:55 PM
Thrush's Avatar
Thrush
Who?
Old May 23, 2006 | 11:19 AM
DanRSturbo's Avatar
DanRSturbo
Powerquest Partition Magic
Old May 23, 2006 | 06:20 PM
Thrush's Avatar
Thrush
I say again - who?
Never heard of it - new software scares me
Old May 23, 2006 | 06:26 PM
DanRSturbo's Avatar
DanRSturbo
You can aquire it from the usual sources, or I'll msn it to you, POP to use m8
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
tib2220
Sep 14, 2015 12:33 PM
