Partition Problem?
Old Apr 3, 2006 | 04:13 PM
adamS2RST's Avatar
adamS2RST
Default Partition Problem?
Hi there,
I have been working on a machine to try and create more space on the system partition as it had only a handful of mb left! Anyway I was using a certain partitioning program and merged the extended partition with some un used space from the disk. (Left the system space alone firstly) I did this, just testing really and now the machine wont boot.
All i get is 'Press A Key To Reboot' each time.
I'm not quite sure what has happend, the program still think's all the data is there and I didn't actually do anything with the system / os partition so i'm not quite sure why the o/s is refusing to load (It seem's to think the primary partiton cannot be found?)
Any idea's what I can do to get it to boot again? - I've booted to dos and cannot see the C: drive at all, and no I can't boot to safe mode either
Any thought's?
Thanks
Old Apr 3, 2006 | 06:41 PM
DanRSturbo's Avatar
DanRSturbo
Run FDISK, and view partiton information in MSDOS. It will only show this if it's a FAT, or FAT 32 partition tho
Old Apr 3, 2006 | 06:59 PM
adamS2RST's Avatar
adamS2RST
They are NTFS Dan....
I can tell i'm not going to be able to boot it again from that partition am i? - I will probably end up slaving the disk off and getting at all the data (I hope ) and then wiping the disk and creating one partition...fook knows why you would partition a measley 10GB disk - Well the machine is an old PII FFS!
Old Apr 3, 2006 | 08:46 PM
DanRSturbo's Avatar
DanRSturbo
You're fooked, unless you can run the repair feature of windows xp, it's pretty much game over i'm afraid m8
Old Apr 3, 2006 | 09:09 PM
adamS2RST's Avatar
adamS2RST
What about slaving the disk off to get at the data? - That shouldn't be a problem should it
Old Apr 4, 2006 | 07:33 AM
DanRSturbo's Avatar
DanRSturbo
Well, the last time I had a partition error, I kissed goodbye to 40 gig's worth of MP3's m8.
I would throw in another drive as a master, (disconnect the one you want to get the data off), install XP or 2000, then connect up the other drive and cross your fingers
Old Apr 4, 2006 | 12:29 PM
adamS2RST's Avatar
adamS2RST
Sorry Dan, I should have mentioned it's a 2K Pro box, not XP.
Anyway, just slaved the disc off to one of the XP test box's at work, job done
It's a little more work than I wanted, but at least it will be properly sorted from now on.
Old Apr 6, 2006 | 01:26 PM
DanRSturbo's Avatar
DanRSturbo
Sorted m8 You was lucky, let that be a lesson to you lad
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
