Saff drivers wheel sticking out more than pas side
As title says folks, my drivers front wheel sticks out about 1cm more than pas side, mibi even slightly more. Its a 4x4 cosworth. Owned car for 8 years, noticed it b4 but never botherd me but i now hav 18's on it and it catches the lip now and then. Camber is ok so thers nothing bent ect... It jst sits out slightly more as a whole unit. Im confused but i need to get to bottom of it. Mibi sumbody has fitted a diffrent hub in past?? Help lol...car drivers perfect btw and has never been in bump
But you say the drivers wheel sits further out than the passenger side do the cambers wrong on 1 of them,could be a 2wd tca on the pass side,bent tca,bent drivers hub.
I'd get the front up and measure all components at both sides and compare measurements then go from there.
Check the wheels if there not....ford might have to different offsets or a staggered set and u have put a back wheel on front......or the good old cossie front bumper is twisted in.......think u will Notice if u have the wrong Tca on or a bent one when u get the power down and
Has it had a replacement wing in the past? I only ask as my mates motor was visually different on the gap between wheel and arch between sides, i checked everything and it was down to a non genuine wing
I had a similar problem on my 4x4. It had a trw track control arm on one aide and a random make on the other. The random one was 6mm longer if my memory serves me right plus I've had a replacement none genuine wing. Took bloody ages between 2 of us (mechanics) to work out what the hell was going on!!
jim_robson
29
06-05-2016 01:49 PM
Indyrs
07-04-2016 09:53 PM
155lee
18
07-04-2016 08:41 PM
MidMog71
26-03-2016 07:12 PM
