Zetec turbo questions
Old 17-04-2015, 01:15 PM
turbobill
turbobill's Avatar
Default Zetec turbo questions
Hello everyone, ive just built a 2.0 zetec turbo for my escort rs turbo il be aiming for about 300-350 so what injectors should i use? Im using omex 600 for management so i know they need to be high impendence ones, and a rover inlet so top fed injectors i would rather slightly bigger injectors then actaul needed so there not maxed out
Second question, do i need a icv as some people say to use them some say dont worry about them,
And third question, wheres best to get it mapped when its all up and running im from ashford kent,
Sorry for all the questions and cheers for any help
Old 17-04-2015, 09:45 PM
Smidydevil
Smidydevil's Avatar
Injectors I would be looking at astra vxr injectors 470cc high impedance top fed and about 100-120 brand new
ISCV no you don't necessarily need one they can run and idle ok without them depends on your own preference
I wouldn't recommend anywhere local myself (margate) I will be travelling to Essex.to get mine mapped probablt with Karlos but best bet is to ring round and find out who will map your car with your set up
Old 17-04-2015, 10:44 PM
turbobill
turbobill's Avatar
Thanks for the reply, il look into them injectors then, same with the throttle body, maybe just get a 63mm throttle body with tps on?? Cheers
Old 18-04-2015, 10:29 AM
Smidydevil
Smidydevil's Avatar
I just used my fiesta rs turbo throttle body with my rover inlet dare say there's better options but can't see you fitting a much bigger tb to the inlet as the FRST is very close to the walls of the plenum
Old 18-04-2015, 10:40 AM
turbobill
turbobill's Avatar
Okay cool thankyou, how did you got about making it fit the rover inlet because i heard you have to modify the inlet or something?
Old 18-04-2015, 07:45 PM
SBT83
Not Crazy, just Unwell
SBT83's Avatar
2wd Cossie tb is a straight fit to the rover inlet
Old 18-04-2015, 07:50 PM
studabear
studabear's Avatar
I would go for Siemens Deka 630cc injectors, thats what I have in mine.
Old 18-04-2015, 10:24 PM
turbobill
turbobill's Avatar
Sweet thanks sbt83 looks like il be getting one of those throttle bodys�� studabear funny enough i got those injectors on my watch list on ebay lol, what are you running ??
Old 18-04-2015, 11:26 PM
Hobomassiv
Hobomassiv's Avatar
Hello fellow Ashfordite. I moved here about a year ago.
There is a company that I know of locally that could do mapping but im not sure if htey are that experienced with ford/omex.
How are you with RS turbos?
Old 19-04-2015, 10:36 AM
turbobill
turbobill's Avatar
Hi mate, where abouts in kent are you then?? What company would that be?? Yea im pretty good with the rs turbos, just needed a litle help on the stuff i wasnt so sure about, nearly there now though
Old 25-04-2015, 08:12 AM
Hobomassiv
Hobomassiv's Avatar
Ashford! J9 side.
This is the company I was on about http://www.fastroadconversions.com/contact.html. They said that they could map OMEX , or know someone that can, not sure on their reputation though never dealt with them. They might be able to get it to a stage where you can take it to one of the ford boys like Oddkid etc.
Old 26-04-2015, 08:59 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
there is injectors for sale on anothet forum that would work for yours bill.
as for mapping thats easy too mate. get it ready
Old 26-04-2015, 05:08 PM
turbobill
turbobill's Avatar
Hobomassiv - oh okay, i live near jct 11
Ive had bad things about them so i wont take it there, thanks though
Versus creations, il have a little look at them then, its getting close now to getting finished
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec turbo questions
