3 Issues - One problem?
Old 10-03-2014, 10:52 AM
bTaryag
bTaryag's Avatar
Default 3 Issues - One problem?
Hi all. I'm trying to figure out what this can be. Three symptoms started more or less the same time on my 2008 Focus.
1. Car vibrates. Not the steering wheel, but the whole lower front end of the car has right-to-left vibrations, mainly at speeds up to 30 mph, mainly when accelerating, particularly bad when driving uphill.
2. When I go over a bump, sometimes there's a thump-like noise from the front right or front left of the car. This issue only exists when the car is cold, but once it's been driven for a while it doesn't happen.
3. When the car is stationary and I turn the wheel from side to side, I hear a clicking noise from under the car. (I sometimes think I also feel it from under my foot.) This only happens when the car is in drive, not in park or neutral. Like issue #2, this issue only exists when the car is cold.
Any thoughts What could this be? Is this one problem or a few separate ones?
Thanks for any help!
Old 10-03-2014, 12:45 PM
RichieST
RichieST's Avatar
Sounds like a knackered suspension bush or balljoint. only way to check is to get it up on a ramp and have a look.
Old 10-03-2014, 01:08 PM
robch1983
robch1983's Avatar
sounds like a dead driveshaft
shane27670 (20-01-2016)
Old 10-03-2014, 01:47 PM
Heitmann
Heitmann's Avatar
Number 1, is exactly like what I had on my 08 focus - it was driveshafts.
Old 20-01-2016, 07:28 PM
shane27670
shane27670's Avatar
i have the same problem with shaking steering wheel and banging on front i thought mine was the lowering springs on it but ya say can be drive shafts? is this because i have lowered it its doing shafts in???
Old 20-01-2016, 07:29 PM
shane27670
shane27670's Avatar
all my bushes n joints are mint
Old 20-01-2016, 10:09 PM
simonmcf
simonmcf's Avatar
Cracked Spring if not shaft or bushes.
Old 21-01-2016, 06:42 AM
shane27670
shane27670's Avatar
new spring on too
dombanks
21-09-2015 08:38 PM
morg65
Escort MK 5 / MK 6
17
11-09-2015 08:40 PM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
andrewmctiernan
08-09-2015 03:05 PM
routemaster
07-09-2015 05:27 PM
Quick Reply: 3 Issues - One problem?
