focua st fuel pressure test ?
Hi all I've got a 2005 focus st-3, got the engine management light on 2 fault codes p0087 and p2178, I'm taking to a local garage who has ford ids vcm, I'm not sure hes used to using fords diagnostics as he normally uses a snap-on kit, does any1 know where there's a user guide for fords ids-vcm or what to check/test with the ids diagnostics?, thanks in advance .
Hi
I have the exact same error. I have a 2006 focus st - modified with a bigger intercooler, full exhaust , induction and dreamscience modx software. The error only happened when I fitted the focus rs 440c injectors. is there any advice you can offer. The Modx meant is meant to work with these injectors as well.
thanks!
thanks!
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
