injector giving out to much fuel
Old 23-11-2009, 11:51 AM
rs turbo 88
rs turbo 88's Avatar
Talking injector giving out to much fuel
helo i have an 88 escort rs turbo. the other day i broke down due to flooding of engine caused by injector, i did replace the injector that was spaying out petrol and it was ok for 5mins and then went back to spraying out of engine in doing so flooding it any ideas ty?
Old 23-11-2009, 06:18 PM
oldford
oldford's Avatar
Check wiring for a short with ground.
Old 23-11-2009, 10:45 PM
martysmartie
martysmartie's Avatar
It's will be MFI, maybe faulty injector, they open at a predetermined pressure and then close below this limit, sounds like yours staying open, if permantly open you may be able to smell petrol when the car is off as fuel will drip into the inlet manifold.
Martin
Old 24-11-2009, 09:34 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
maybe a metering unit fault, as said they only open at a certain pressure and close when this drops, there is no other control over the injector.
Old 02-12-2009, 06:55 PM
rs turbo 88
thanks for reply, think it is metering unit its spraying 2 meters out of the bore onto floor thought it might be fuel pressure regulator but seems to be working,i disconnected all of the wires to the mfi unit from the mfi ecu and was stil spraying shit loads of fuel.
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
17-09-2015 12:37 PM
markk
09-09-2015 08:11 AM
kevin36
08-09-2015 12:23 PM
Quick Reply: injector giving out to much fuel
