mercury grey 2wd cossie
Old 27-10-2014, 10:57 PM
cossie brad
cossie brad's Avatar
Default mercury grey 2wd cossie
posted on another site on 22.07.14
So been fancying a 2wd ever since I bought my 4x4 back in 2007 and while on my way back from Donington on Sunday I spotted a 2wd I could afford to buy and keep my 4x4! It needs a fair bit of restoration but everything is there and it's completely standard, anyway this is what I bought.
As you can see from the photo's it's going to need a full respray there is a few bits and bobs that need replacing, I'm gonna start stripping it down at the start of next month got a week off so I'll keep you guys up to date with it.
Old 27-10-2014, 11:02 PM
cossie brad
Once I seen it was a good solid shell I couldn't break it! While at Ford Fair I collected a few bits and bobs mostly from Matt Lewis, I got HT leads, plugs, dizzy cap, rotor arm, TCA's, cam belt, fuel pump loom and a new oil filter. On Monday it was off to a local scrappy to get some little bits that were missing like the nut to hold on the steering wheel, pedal rubbers and the headlight plug and washer light plug had been cut off so picked them too. Got a little bit of time to get stripping it when I got back so this is how it looks now.
Old 27-10-2014, 11:05 PM
cossie brad
Also noticed the clocks font looks strange on this and has a badge saying IRS NOTTM certificate no. 924699
I haven't seen cossie clocks with the same font before, it does go up to 170mph.
had some fun too removing the one caliper, even though the bolt was already wound half way out it had been that way so long it was stuck solid! a soaking over night in WD-40 and trying to work it either way to free it still ended in the bloody bolt snapping! It couldn't snap flush to the hub either! oh no! it snapped half way through the caliper so I had a hell of a job getting it off the hub and disc!
That's all off now but it doesn't look as if the 4 pots can be saved so the next thing on the shopping list is a pair of standard 2wd calipers.
Old 27-10-2014, 11:08 PM
cossie brad
Little bit more done today, got the TCA's fitted. Originally i had planned on keeping the original TCA's and fitting new bushes to them but as the ball joints were shot I got new TCA's at ford fair, but I had already ordered the Powerflex bushes for it so I ended up fitting them to the Magenta 4x4 today as well which slowed progress a little on the 2wd, but I still got tomorrow and Friday before I'm back to work so hopefully get a bit more done. Really that's all I want to get done now before it goes in for paint is the brakes so shouldn't be long now just need to get front calipers sorted out.
Old 27-10-2014, 11:09 PM
cossie brad
Lights turned up today! 8-)
Plus I got a set of front wings on order with the main dealer, tomorrow it's off to the bodyshop to start getting the paint sorted out.
Old 27-10-2014, 11:11 PM
cossie brad
Well not a lot has been happening with the car lately the bodyshop is taking it's time I popped over on the 1st of this month and this is how it's looking.
When they rubbed down the bonnet and bootlid they found they had gone too bad so I had to find replacements, I got them now and dropped them off to the bodyshop on Wednesday this week so hopefully work will crack on a bit quicker now. Also I have had the cracked windscreen removed and I am having a heated one fitted in it's place.
Old 27-10-2014, 11:14 PM
cossie brad
today
At last I got an update! It's back from the bodyshop! 8-) Still lots to do but I'm looking forward to getting stuck into it, I got the weekend off so I'm sure I'll more to update then but for now here are some photo's.
Old 28-10-2014, 06:28 AM
lee2cossies
lee2cossies's Avatar
Great work so far what a transformation from when u picked it up. Good work for saving it, look forward to seeing it being built up and going sideways. Lol
Old 28-10-2014, 07:18 AM
AJC
AJC's Avatar
good on you for saving it, keep up the good work
Old 28-10-2014, 08:03 AM
rog
rog's Avatar
Looks like a good one worth saving!
Do you know the history of the car? Those are the clocks cossie police cars used does it have any other odd bits that look out of place?
Old 28-10-2014, 09:06 AM
lee2cossies
When we looked it has a hole in the roof, extra holes on front crossmember and lots of extra wireing to the lights and behind dash so possibly ex CID car?
Old 28-10-2014, 09:13 AM
rog
rog's Avatar
Most likely, or something of that order. Nice bit of history to add to the story of car. Maybe worth paying for one of those vehicle enquiry checks for previous owners to see what comes back if there's no paperwork with the car.
Contact them and ask for information, worth a go
http://www.irs-gb.com/?sl=EN
Old 28-10-2014, 09:18 AM
Weaver
Weaver's Avatar
That's a calibrated speedo. IRS used to do a lot of the plod cars so it must be ex police. That makes even cooler. Really pleased to see another one saved. You should try and find out a bit more about its history.
What are your plans for it? An early Saph on lattice with ambers is hard to beat!
Old 28-10-2014, 01:22 PM
chris cdti
chris cdti's Avatar
As said IRS Nottingham dials are police calibrated dials. If the car was a police car it would of been an unmarked traffic car not cid. It would be worth getting the old log books from the dvla to see if it was owned by a police force. Also it may be worth speaking to irs Nottingham and giving them their calibration number to see if it belongs in that sapphire as it may of come out of one of the many late spec 4x4 police.cars.
Old 28-10-2014, 03:26 PM
cossie brad
Some great info there thanks guys I will dig into the history a bit more soon, plans for the moment are to restore it to standard, then I need to decide whether I am going to keep this or my Magenta 4x4. If I do keep this I will probably do a modern stage 3 and fit a set of Compomotive MO5's in 17" I got sitting in the garage along with bayjoo springs and koni shocks and probably a set of 4 pots or 6 pots with 330mm discs, nothing to drastic and all stuff that I could put back to standard if I ever wanted.
Old 28-10-2014, 04:39 PM
Cos500
Cos500's Avatar
Love it, nice find and some good work, want to keep mine on standard wheels but brake choices are few
Old 10-11-2014, 10:11 PM
cossie brad
Thanks Cos500 Haven't had much time to work on it since I got it back so only a couple of little jobs done, put the new tail lights on and the number plate
and started tidying up under the bonnet, there is a lot to do here though.
wiper motor next when I got a bit of time.
Old 12-11-2014, 09:16 AM
bull-turbo
bull-turbo's Avatar
Hi Brad only jus seen this looks really nice! let me now if u guna keep it got a few stage 3 parts here off my cars mate!
Old 12-11-2014, 09:54 AM
james kiely
james kiely's Avatar
excellent work brad ,another saved
Old 12-11-2014, 11:05 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Good project looks well after paint
Old 12-11-2014, 03:44 PM
Nash
Cake lover!
Nash's Avatar
The bodyworks looking really good now.
Old 13-11-2014, 07:46 PM
Cool project and it would be interesting if it was a cop car.
Old 17-11-2014, 10:35 PM
cossie brad
Thanks rog for the link I just sent IRS an E-mail to see if they can give me any info on the clocks, I'm also going to send off a V888 soon, thanks to the rest of you guys to for the comments, hopefully I'll get a bit more done on it this week.
Old 17-11-2014, 10:40 PM
cossie brad
thanks Alex I'll let you know if I want some stage 3 bits, I got to decide which I'm going to keep the 4x4 or this as I'm hoping to get a house soon and one of the cars are going to have to go to go towards a deposit.
Old 18-11-2014, 07:27 AM
Guinnless
Guinnless's Avatar
Thumbs up
Really well done. Looks like you've got a very interesting car there.
Old 18-11-2014, 08:04 PM
mk22door
Fart of the Purniture
mk22door's Avatar
I LOVE Mercury grey Saffs.
I shall subscribe, looking good.
Old 18-11-2014, 08:16 PM
chris cdti
chris cdti's Avatar
I would be interested to see what IRS Nottingham say about your dials ��
Old 19-11-2014, 08:49 AM
rog
rog's Avatar
Good luck with your enquiry, I hope they at least get back to you and don't just ignore it.
Nothing worse when you take the time to be courteous and don't even get an acknowledgement, even to tell you to piss off and they can't or won't help you lol.
Old 19-11-2014, 10:59 AM
chris cdti
chris cdti's Avatar
when I asked about the ones in my old V6 mondeo I got nothing back off them.
Old 20-11-2014, 07:10 PM
Brian
Brian's Avatar
Nice project
Brian
Old 21-11-2014, 02:16 AM
rog
rog's Avatar
Keep at it, pester them and call them up, it's way easier for people to ignore emails, if they've already picked up the phone it's too late by that point for them to back out of at least having a conversation
Old 21-11-2014, 12:11 PM
gcfcos
gcfcos's Avatar
Nice job your doing there. Good to see one being put back on the rd and not broken up
mark r
29-09-2015 07:27 PM
Eigdoog
48
19-09-2015 11:03 AM
3doorcozmess
15-09-2015 06:06 PM
dojj
28
11-09-2015 10:00 PM
rsstav
07-09-2015 04:43 AM
Quick Reply: mercury grey 2wd cossie
