Zetec turbo escort. Nearly there...
Old 14-09-2014, 05:57 PM
  #121
xr3iturbo
ON THE ROAD AGAIN
xr3iturbo's Avatar
Break masters and reservoir not bit close to turbo ? for heat transfer
T
Old 14-09-2014, 06:07 PM
  #122
s1cab
s1cab's Avatar
It's 7 inches away plus will all be wrapped so won't be a problem
Old 28-09-2014, 04:10 PM
  #123
s1cab
s1cab's Avatar
Pictures of the compression struts fitted, trial fitted the black top sump today and need to take a little more webbing off before it will fit properly. Then I can get the oil pump all mounted 😀
Old 28-09-2014, 07:19 PM
  #124
marky_g
Fleet Manager
marky_g's Avatar
So the compression struts replace the roll bar?
Old 28-09-2014, 08:14 PM
  #125
frsjon
frsjon's Avatar
will be good to see if the alternator still bolts straight on with the oil pump fitted..it wont with my set up..might need to lift it up and find a longer belt
Old 28-09-2014, 09:26 PM
  #126
s1cab
s1cab's Avatar
Yes you remove the anti roll bar
Old 28-09-2014, 09:27 PM
  #127
s1cab
s1cab's Avatar
It def fits on mine.
Old 29-09-2014, 09:16 PM
  #128
frsjon
frsjon's Avatar
nice one..can you take a pic
Old 14-10-2014, 12:41 PM
  #129
s1cab
s1cab's Avatar
Will have sump back late this week so can get engine finished within the next few weeks, then it's rear suspension and fuel lines
Old 22-11-2014, 08:57 PM
  #130
cossirob
cossirob's Avatar
Any update on this build? Interested in the external oil pump set up?
Old 27-11-2014, 08:19 AM
  #131
s1cab
s1cab's Avatar
I will have oil pump fitted before christmas, work is very busy atm so finding it hard to get free time. Will update as soon as it's fitted
Old 27-11-2014, 09:16 AM
  #132
It's Czech Mate
It's Czech Mate's Avatar
Dont you have to run really hard spring rates to controll roll when you use compression struts on their own? How are you approaching this?
Old 28-11-2014, 11:57 PM
  #133
Scott_Rst
Scott_Rst's Avatar
Awesome car mate,
Where did you get youre compression struts from?
Old 29-11-2014, 08:25 AM
  #134
Dan F
Dan F's Avatar
Just seen this and wow is all i can say, loving the build mate
Old 29-11-2014, 08:42 PM
  #135
s1cab
s1cab's Avatar
Once suspension is all fitted i'll be getting it corner weighted so will change spring rates accordingly
Old 29-11-2014, 08:43 PM
  #136
s1cab
s1cab's Avatar
Originally Posted by Scott_Rst
Awesome car mate,
Compbrake they're 2wd cosworth compression struts
  #137
s1cab
s1cab's Avatar
Old 30-11-2014, 09:10 AM
  #138
It's Czech Mate
That's what I'm saying, you're going to end up with hard spring rates for the road or tons of roll, can you not get an after market arb to help you keep softer springs and tame the roll a bit
Old 01-12-2014, 12:12 PM
  #139
s1cab
s1cab's Avatar
I can get one custom made, but its going to be a track car
Old 05-03-2015, 01:16 PM
  #140
cossirob
cossirob's Avatar
Hows this project coming along? I was keeping an eye on your build for a few ideas.
Old 12-03-2015, 07:32 AM
  #141
s1cab
s1cab's Avatar
I started working on it again last weekend so there will be lots more updates very soon
Old 15-07-2015, 05:22 PM
  #142
s1cab
s1cab's Avatar
Have done lots of buying parts over the last 6 months and now have some free time to crack on with this. Finally got the black top sump all fitted with the tails welded in.
Old 10-08-2015, 07:28 PM
  #143
s1cab
s1cab's Avatar
A few updates on the build, External oil pump is all fitted just got the outlet pipe to fit. Had inlet, boost pipes and turbo hanger powder coated.
I have a bit of free time now so hoping to finish the front end in the next couple of months
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec turbo escort. Nearly there...
