sierra with volvo engine
Old 03-12-2011, 05:19 PM
alastair402
alastair402's Avatar
Default sierra with volvo engine
I bought this car off my mate its 2.5 turbo. My plan is to put the engine into a sierra shell i bought a couple of months ago.
Old 03-12-2011, 05:20 PM
Mark_
Mark_'s Avatar
sounds intresting,
make sure you post up pictures
Old 03-12-2011, 05:50 PM
alastair402
Old 03-12-2011, 05:51 PM
alastair402
Old 03-12-2011, 05:54 PM
PileOfRust
PileOfRust's Avatar
fuck me thats abit mangled! what happened to that?
alastair402
car was used in a couple of demolition derbys hence the state of it. the engine is running like a clock tho.
kev 3dr
kev 3dr's Avatar
What type of sierra shell it going in and what gear box you going to use ??
Old 03-12-2011, 06:03 PM
alastair402
its going into a magenta sapphire 4x4 shell. its only gona be rwd tho. I aint sure wat gearbox to use yet. Either i make a bell housing for a type 9 or i mod 2 volvo boxes to suit. I sorta wanna stay away from the standard type 9 because of the power issue. i have already bust 3 type 9 boxes on my other 24v cosworth sierra. i am open to all sugestions as i know very little about the engine or wat will fit on it.
Old 03-12-2011, 06:04 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
volvo TD 5cyl is RWD out of early 740 760, i used this to put a 5cyl turbo audi motor into a saff. All bolts together fine, swop flywheel i think too.
(volvo/vag TD block is same as Audi petrol turbo bolt pattern)
Good conversion this
Old 03-12-2011, 06:21 PM
kev 3dr
kev 3dr's Avatar
Easiest is a 960 gearbox as its the same bolt pattern as this otherwise its either make an adapter up or get a adapter of a firm think its in sweden who mate them up to BMW or Supra gearboxes as ive been looking into putting one in a e30
Old 03-12-2011, 08:06 PM
fiestamk2
fiestamk2's Avatar
Good read i will be watching this closely
Old 03-12-2011, 09:05 PM
Cossie Sean
960 with adapters, i can see the sense in that.
going to that extent id be after an E46 m3 or E39 m5 manual box personally, even a late 6sp 330 petrol non turbo box Kev.
Absolutley awesome power plants but im Audi 5 pot at heart, since Volvo copied everything about it in diesel form then in petrol 20v awesomeness but im biaessed massively by my A4 that i converted and then theres the noise of a genuine Audi 20v...... wow.......
Old 04-12-2011, 12:54 AM
surrey_100e
surrey_100e's Avatar
i mated mine to a cosworth t5 gearbox check out my thread, it should help alot!
Old 04-12-2011, 08:28 AM
fiestamk2
fiestamk2's Avatar
Hi mate i read your thread on vpcuk.You had to use cutoms bits didnt you lol.I was hoping there might be a box about that would mate up to the volvo engine besides the m90 box
Old 04-12-2011, 11:36 AM
fastfezzy G
ladiesman.
fastfezzy G's Avatar
dats gunna be sick man! be like a focus RS but rwd
Old 04-12-2011, 03:08 PM
surrey_100e
yeah i made the adaptor plate between the gearbox and bell housing that is all. I could of used the volvo box but apparently the t5 can handle more power.
Old 04-12-2011, 09:49 PM
alastair402
I took the engine out today. I just realised how much work i have with the wiring loome.
Old 04-12-2011, 09:57 PM
alastair402
Any body know how to bypass the coded key and the immobiliser on this as i dont want it in the sierra
Old 06-12-2011, 05:40 PM
escort1989uk
escort1989uk's Avatar
I'm guessing easiest route would be after market management
Old 09-12-2011, 03:12 PM
merkur
merkur's Avatar
Subscribed!
Old 09-12-2011, 03:34 PM
Steve the Plumber
The original Rouge Trader
Steve the Plumber's Avatar
What a cracking conversion!! and wow, thats some wiring loom!!
Old 09-12-2011, 10:21 PM
Will be a fun project this.
Old 10-12-2011, 06:56 PM
johnandhissaffy
white fords look best
johnandhissaffy's Avatar
what sort of power would this engine give out ?
Old 10-12-2011, 07:04 PM
PileOfRust
PileOfRust's Avatar
think its about 230ish standard
Old 11-12-2011, 06:59 PM
alastair402
I did a little work to the wiring this week and got the engine to fire up out of the car. i now just have take out all the wires that aint needed to run the engine.
Old 11-12-2011, 07:11 PM
alastair402
click on the pic to watch the video
Old 11-12-2011, 07:44 PM
becca180
becca180's Avatar
She sounds well in the video. Keep us updated!
Old 17-02-2015, 06:49 PM
trevor sierra
trevor sierra's Avatar
Default t5 sierra
Hi hows things im new to this hope im messaging the right fella did you ever put t5 into sierra after thanks regards trevor
Old 23-11-2016, 11:05 PM
Conorford
Conorford's Avatar
Default Volvo powerd Sierra?
hows it goin new to this here but which Volvo engine do you use and which model does it come out of thanks
Old 16-12-2016, 02:06 PM
tincho84ar
tincho84ar's Avatar
Sweet project mate, looking forward to see the results, best of lucks
Old 17-12-2016, 09:16 AM
Caddyshack
Caddyshack's Avatar
I expect revo technic can delete keys and clock etc for the immobiliser
Old 24-01-2017, 09:57 PM
rog
rog's Avatar
This is an old thread but still good to see👍I recently posted a thread asking for info on doing a Mk2 focus ST conversion to a saph so I assume this would be similar. Love the 5 pot turbo note
Old 11-10-2022, 11:15 AM
william1998
william1998's Avatar
How’s it going managed to come across this thread about doing Volvo turbo swap on a Sierra, planning on doing this myself. Any feed back be great full
Vincereese
15-08-2015 06:24 PM
Vincereese
11-08-2015 08:44 AM
Old ford
31-07-2015 06:50 AM
Quick Reply: sierra with volvo engine
