My BMW 320D M Sport (Dyno Update!)
Old 03-12-2011, 12:46 PM
James @ M Developments.
James @ M Developments.'s Avatar
Default My BMW 320D M Sport (Dyno Update!)
I purchased this car about 8 months ago, as a bit of an all rounder, thought it was time to do some sort of project thread on it, as its had quite a few mods now. Ultimately i want the car to stay looking pretty much as it does now because its very pretty and i want it to remain very economical to run, but also be a little bit of fun when i want a blast around the lanes.
So here it is. A 320D M Sport Coupe
One of the first mods i carried out was to get rid of the factory stereo unit and fit a phone compatible Kenwood unit, and a full set of Vibe slick Speakers.
The rear speakers didn't fit due to the tweeter size so i had to mod the covers to allow them to stick though
Then it was time to do a little engine work.
These motors are prone to suffering from swirl flap problems, so the inlet was removed to find one of the swirl flaps broken off and literally sat in the manifold!
Very close to killing the engine!
So the flaps were removed and i tapped the manifold to blank the holes where the swirl flaps once were.
Also while i was there, i cleaned the whole inlet and the EGR.
Having covered 150,000 miles, this sort of maintenance is critical!
A few parts were now fitted, New K+N filter, the inlet neck was modified to allow more air flow into the filter housing.
All the oils were changed, using nano tech gear and diff oils.
A full set of Dimple magnets were fitted.
And i carried out a full service, noting a few items that needed a bit of work.
A set of poly front wishbone bushes were fitted to tighten things up a little
A new set of Grooved and dimpled discs were fitted front and rear. Along with some funky pads! and a full fluid change with race spec RBF fluid.
A while i was there i had a new full set of Falken ZE tyres fitted.
A decat front pipe was sourced and fitted, while i was there i also removed the internals from the second cat box, so its now a full decat exhaust system.
So at this point it was time to make the most of these new mods, Working with kenny we made a base map with EGR delete to keep the EGR closed to avoid further manifold clogging! And we spent several hours custom mapping the car. The results are staggering! We estimate we have gained around 60bhp and around 80nm of torque, but she will go on the dyne when I'm happy I've got all i can from her.
On a steady cruise it is now returning 62mpg, and averaging 40+ during my normal weekly drive.
It goes really well, pulls so well from low revs and flies up to 150 in no time
has a few issues with traction though
The turbo is working pretty hard and at almost 2 bar so i am looking into different turbos to allow a little more
A set of HIDs were fitted along with main beam and front fog light bulbs to match the colour, the headlights are much much better now, and it looks really well with them fitted!.
I will try to keep this updated, as mods are coming along quite fast now, and I've missed loads off whats been done so far to achieve the results we have so far, if i list them all ill be here all day
Next mods are a large front mounted intercooler, and a Z3 short shift gear lever and bushes. They should be on soon.
I will get some more up to date pics later, as these are all a bit old.
Old 03-12-2011, 12:53 PM
Also looking into fitting a LSD, as the open diff the car has really is a set back. With the new power it would really benefit from a LSD.
Old 03-12-2011, 12:58 PM
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
looking well james. Always like the e46
LIMITLESS
LIMITLESS's Avatar
Very nice little write up mate, hope to see some more updates soon
We have alot of trouble with the swirl flaps on the Saab engines mate & it seems that every modern diesel has egr problems.
Old 03-12-2011, 01:01 PM
Its so nice to drive now, from when i first got it to now is like night and day
steering is nice and tight, brakes work really well,
Nobody who drives it believes its a 2L its got some real legs when you wind it up
I find myself out driving it, just because i can The std M Sport suspension is really nice, very well balanced. I was tempted to go coil overs etc, but at the end of the day i don't want to ruin what it is, and ruin what its already really good at. It just does everything really well.
Ive pin pointed and sorted pretty much every rattle creak or groan, so its almost silent to drive aswell
Old 03-12-2011, 02:34 PM
hybridford
hybridford's Avatar
Informative and well written write up mate
Old 03-12-2011, 05:45 PM
mackers
mackers's Avatar
Great write up, I have a 2001 E46 330d Sport and intend to go along the lines you have. I want to keep it standard looking but upgrade brakes, renew the suspension parts as they are getting tired and give it some more grunt. I`ve heard the front decat makes a great difference, what about the back one, what will you do come mot time? I also keep hearing that the gearbox and diff are the weak link if you tune them too much, have you heard anything like this? Hope to see more updates from you soon.
Old 03-12-2011, 05:56 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Bit more luxurious than the old Corsa van eh
Does the M3 diff fit? After an LSD for mine as well as it's no fun with the ASC off and only one wheel spinning
Old 03-12-2011, 07:01 PM
I don't think the m3 one will fit, I've had kennys out and it looks pretty different, quaife do a LSD kit though
Old 03-12-2011, 07:03 PM
Mot is no problem at all the test on diesels is dead easy to pass.
Getting the cats out made a great difference!
I've had no drivetrain issues at all so far
Old 03-12-2011, 08:01 PM
BRAMMER
BRAMMER's Avatar
Looks really nice at the mileage James
Is it fine to delete the EGR out as i'm contemplating doing my Golf as it seems to be suffering from bad MPG (33mpg urban) on a PD115 on 135k
Old 03-12-2011, 08:23 PM
Yes Ive had no issues at all with it, we do loads
Old 03-12-2011, 09:26 PM
jaimesdna
jaimesdna's Avatar
looks good. im trying to talk the missus into getting a 330d touring. by what i hear there pretty quick with a remap
Old 03-12-2011, 10:41 PM
mackers
mackers's Avatar
Thats good to hear, whats the mod to the intake that you`ve done?
Old 04-12-2011, 10:02 AM
Just a few little tweaks to optimise air flow into the filter housing
Old 04-12-2011, 10:09 AM
Received 1,044 Likes on 998 Posts
Nice car.
Old 08-12-2011, 11:50 AM
WSD
WSD's Avatar
Nice looking car mate - the 2L diesels have always been the best engine in BMW's to my mind. Always makes me laugh when people think its got nothing then you leave them for dead at the lights! I had a 520d but didn't have the M package - so a little bit envious!
http://www.weldingsuppliesdirect.co.uk/
Old 10-12-2011, 09:57 AM
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
Interesting project this. How much has it roughly cost to get the engine to its current level of tune?
I've always been interested in getting a 320d or perhaps a 520d but the real life MPG values people have told me were rather poor - circa 37-42MPG. I'd consider buying one and doing these mods if it was cost effective.
Old 10-12-2011, 10:23 AM
I've spent a fair bit if time doing it, but used little parts really, I'll try and work it out later
Old 10-12-2011, 10:24 AM
AGAR-COSWORTH
Redumbdancy
Cheers James, that would be useful.
Old 11-12-2011, 08:47 PM
Well I've just ordered a uuc 6 speed short shifter kit
Supposed to be the best there is, height adjustable aswell as a much reduced throw
Pics when it arrives, it had better be nice it cost way too much lol
Old 15-12-2011, 05:51 PM
Well it's arrived, I've done a dummy fit just to see if I like it, and it's very very nice!
Shift is now really precise, goes onto gear with a lovely mechanical thump just how I like it, and the throw is nice and short. Almost feels like a mk1 mx5 gear change now.
So it's all coming apart for a proper fitting soon along with the bushes etc being changed so I'll get some pics up
Definitely a worth while mod though!
Old 15-12-2011, 06:25 PM
gouch1
gouch1's Avatar
good work neat job on the speekers
Old 15-12-2011, 06:30 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Love it James - The car is a credit to you and having seen how well it's looked after it makes a nice change
I have a cunning plan for next year though, it will involve an E46 of some description and an M62B44 engine
Old 15-12-2011, 06:36 PM
Carlos-Titx
Carlos-Titx's Avatar
Did this replace a 3 or 5 series?
One was parked by mine in Blackpool months ago, bought to rent place.
Looking good! Do like these cars.
Old 17-12-2011, 07:03 PM
one_nineRS
one_nineRS's Avatar
Nice car..been thinking about getting one of these next year..apparently you can get
upto 600 miles on a full tank..is this true?
With petrol prices amounting to what can only be described as legalised theft, getting
a nice diesel is clearly the only way forward..
Old 17-12-2011, 07:07 PM
PhilM
PassionBMW.com Member
PhilM's Avatar
Looks great mate. I must get round to some poly wishbone bushes on mine, did them 30k ago with standard ones, and theyre almost shot already!
Is it a EURO4 car? If so, I assume with the remap you managed to inhibit the check engine light with the EGR kept closed?
Old 17-12-2011, 09:16 PM
Shorty
Shorty's Avatar
Nice car.
I like these, my best mates got a 330CD, i mapped it using the Evo software and its got a decat too, made 280bhp and 480lb/ft. Serious car, goes VERY well!
Old 18-12-2011, 09:30 AM
AGAR-COSWORTH
Redumbdancy
Good progress there James - have you had a chance to work out how much you've spent on it so far. I'd be keen to know
Old 18-12-2011, 11:24 AM
I've done work reports for all the work I've done and the retail is about 4k!
Old 18-12-2011, 11:26 AM
The standard carbon interior trim was looking a little old, so I decided to re wrap it all in new carbon vinyl
Looks much better now, just the interior door handles to do next.
Old 18-12-2011, 11:27 AM
Yes, no lights on at all or faults show on the Ecu,
Old 18-12-2011, 11:39 AM
Mark_
Mark_'s Avatar
James im guessing the same gains can be had on the 320d Touring aswell?
how much would the remap roughly be to see the same gains as yours?
Old 18-12-2011, 11:56 AM
In house it would be around Ł400 to spend a little time perfecting it.
Old 18-12-2011, 12:01 PM
Mark_
Mark_'s Avatar
thats seems pretty good, would you advise changing the turbo at the same time or would the stadard turbo be ok running at 2bar?
Old 18-12-2011, 12:24 PM
They run a lot of boost as std mate I've only increased mine very slightly
Old 21-12-2011, 02:54 PM
well Stu still has an M5, and Kenny has an M3, so maybe it was one of those! probably on the way to the petrol station
Old 21-12-2011, 03:10 PM
Carlos-Titx
That was Kenny then.
Old 21-12-2011, 03:15 PM
This winter grade diesel is effecting the fuel ecomomy a bit, i notice a 5mpg drop since the temps are down, and a bet a fair bit of that is because of the fuel adatives to prevent it freezing,
Maybe ill have a play and make a winter fuel map.
Old 21-12-2011, 03:22 PM
Jay,
Sponsor
Jay,'s Avatar
LOL why am i not suprised nice clean mods James ! What are the servicing costs like?
Quick Reply: My BMW 320D M Sport (Dyno Update!)
