Rear Arches for 2WD Saff
Old 29-11-2011, 12:48 PM
RS_Andy
RS_Andy's Avatar
Default Rear Arches for 2WD Saff
Hello All,
I need to repair both my arches on the cossie as you can imagine the curse of ford has sunk its teeth on them. How is the best way of getting these sorted, is getting a panel beater best to get these repaired. (Ive been trying to get doner arches but not has no luck). Has anyone does this, and is this an expensive job?
Any advised would be greatful
Andy
Old 29-11-2011, 12:58 PM
BigErn
BigErn's Avatar
Cut rotten metal out and replace with new metal is the only way to stop the tin worm spreading mate.
Any good bodyshop should be able to do it, chances are that you will find some rot on the inner arch too once you have removed the outer skin so that will need sorting too.
Old 29-11-2011, 01:04 PM
RS_Andy
RS_Andy's Avatar
Cheers Big Ern,
I went to one body shop and they said to me to get donor arches as this is a better way, sounded odd to me. I thought making new arches was the better way.
(I dont know if im allowed to ask, but does anyone know are there any good body shops that will do this)
Old 29-11-2011, 01:06 PM
BigErn
BigErn's Avatar
You can buy arch panels mate, no need to make your own or buy 2nd hand ones. Or at least you could do a few year ago when I done one of my old Sapphs. I think they were about Ł16 a side.
Where abouts are you? Your location says London but you have a Newcastle badge in your sig, are you down there or up here?
Old 29-11-2011, 02:32 PM
sarmac77
sarmac77's Avatar
as above,when i did mine they were about 15 quid a side, inner arch will probably need repaired too,this is usually done by making up small pieces from scrap steel, i got my outer panels from brown brothers
Old 29-11-2011, 03:01 PM
sarmac77
sarmac77's Avatar
Old 29-11-2011, 03:02 PM
sarmac77
sarmac77's Avatar
whoops
Old 29-11-2011, 03:39 PM
RS_Andy
RS_Andy's Avatar
I'm in London BigErn. I have family in Newcastle but live in North London. I've been on the net till the point my fingers were bleeding from the keyboard searching. I've been on so many websites trying to find out what I can do but I've hit a wall everytime, Is this something I would get and take to a body shop. Sorry for all the questions. This is the best help I've got up till now.
Thank you guys.
Old 29-11-2011, 03:47 PM
rostill2007
rostill2007's Avatar
try carz2.com they supplied me sierra arches about 6months ago when i wanted mondeo arches
Old 29-11-2011, 07:27 PM
neil andeRSon
neil andeRSon's Avatar
Right hand side..
http://hadrian.dominohosting.biz/had...cument&Ret=ALL
Left hand side...
Old 29-11-2011, 07:41 PM
RS_Andy
RS_Andy's Avatar
Neil is that you mate ?
I have those repair panels but the rust I have is on the curve just under where the door latch is. That's why I was told it would be easier to get the arch.
Old 29-11-2011, 07:49 PM
neil andeRSon
Sure is Andy. I've got a hatchback at work am gonna be cutting up. I'll pm you my mob no. Can you send a pic of the area you need and i'll get it cut ASAP.
Kyle Langford
27
05-08-2019 07:54 PM
fuzzy
21
15-02-2016 10:26 PM
turbotrev
14
06-09-2015 10:27 AM
mint_s2
02-09-2015 08:58 AM
FlashRS
13
31-08-2015 06:02 PM
Quick Reply: Rear Arches for 2WD Saff
