subaru sti 2003 550+bhp build
here is the spec of the car
engine spec
2.0cdb bored n stroked to 2.146cc
all engine work carried out by alan jefrey includes
79mm nitrided crank shaft
cosworth con rods
cosworth enginetuner spec stroker pistons
roger clark 14mm head stud conversion
jdm /spec c big port heads ported by enginetuner
cosworth iconel exhaust valves
cosworth stainless inlet valves
cosworth double valve springs
cosowrth titanium retainers
cosworth guides
cosworth head gaskets
cosworth 12mm oil pump
cosworth kevlar timing belt
cosworth sump baffle plate
cdf racing timing belt guide
cdf racing light weight pulleys
cdf racing exhaust cam pulleys
aps 8 injector tumble bodies
550cc sti injectors
1000cc injector dynamics injectors
roger clark motorsport twisted kit
gt35/82r turbo
hdi front mount intercooler
3" japspeed system coupled with rcm twisted down pipe
fuelab 3 port fuel pressure reg
fuel lab prodijy fuel pump
fuel lab filter
swirl pot in boot
alloy rad
syvecs ecu
Transmission:
std uk sti6 speed non dccd box
exedy hyper twin clutch
Chassis:
bc racing br series coilovers
whiteline 24mm rear arb
whiteline 22mm front arb
whiteline rear arb drop links
whiteline front arb drop links
cdf alk
front strut brace
rear strut brace
flow flex pitch stopper
8x18 inovit redline wheels
brakes:
k-sport 356mm 8 piston front brakes
k-sport 330mm 6 piston rear brakes
ferodo ds2500 pads front
k-sport pads rear
styling:
lester front spoiler
rest standard
this was it when i got it.
then i got bored with its power
and bought a fp green hdi fmic simtek 800cc pe 3" cat back and some 356 8 pot ksports
how it was under the bonnet pushing a healthy 420ish bhp last dyno was at 1.6 bar where it did 400/400
battery fitted in boot
sender modded for -6 in and out
under bonnet fuel lines modded to -6 fitting
fuelab prodigy 1000hp pump n filter
apex classic alloy 50mm rad
cdf adjustable avcs exhaust pulleys
oil cooler 19 row
a few various parts
pistons new enginetuner cosworth stroker
same rods as in this pic
rcm 14mm head studs
cosworth 12mm oil pump n kevlar belt stolen pic!
header tank modified:
wiring from battery in boot sorted:
8 injector aps inlet:
engine spec
cosworth con rods
cosworth guides
550cc sti injectors
gt35/82r turbo
fuel lab filter
swirl pot in boot
alloy rad
syvecs ecu
Transmission:
Chassis:
cdf alk
front strut brace
rear strut brace
brakes:
k-sport pads rear
styling:
rest standard
oil cooler 19 row
a few various parts
rcm 14mm head studs
Irregular Poster
07-10-2015 12:56 PM
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
