GoKart rebuild GSXR 1000cc finished VID NOW ADDED!!! ALSO FOR SALE £3750
#41
Lucifer II - 666
Update
Originally Posted by timbhp
right done some more on kart so here are a few more pics, time is getting close now 18 days to go with so much to do
![](http://i1002.photobucket.com/albums/af148/timbhp/003-1.jpg)
brass bush and mounting boss to weld on chassis for gear leaver
![](http://i1002.photobucket.com/albums/af148/timbhp/004-1.jpg)
bush pressed in boss
![](http://i1002.photobucket.com/albums/af148/timbhp/006-1.jpg)
gear leaver assy grease nipple with hole drilled through to feed brass bush
![](http://i1002.photobucket.com/albums/af148/timbhp/007-1.jpg)
bush in place
![](http://i1002.photobucket.com/albums/af148/timbhp/008-1.jpg)
with nice momo bit
![](http://i1002.photobucket.com/albums/af148/timbhp/011-1.jpg)
offered up in place
![](http://i1002.photobucket.com/albums/af148/timbhp/031-2.jpg)
walbro high pressure pump with ally filter
![](http://i1002.photobucket.com/albums/af148/timbhp/017-3.jpg)
one off pace rad cores with own end tanks and take offs
![](http://i1002.photobucket.com/albums/af148/timbhp/014-1.jpg)
both rads
![](http://i1002.photobucket.com/albums/af148/timbhp/016-1.jpg)
a few more bits to go on
![](http://i1002.photobucket.com/albums/af148/timbhp/027-2.jpg)
body work ofered up
![](http://i1002.photobucket.com/albums/af148/timbhp/013-1.jpg)
starting to look like a kart
the gap between wheel and body work is for rads one each side
![](http://i1002.photobucket.com/albums/af148/timbhp/033-2.jpg)
brakes
all pedals fited
![](http://i1002.photobucket.com/albums/af148/timbhp/001-2.jpg)
brake pedal box with twin master cyls so can alter bias to f & r
![](http://i1002.photobucket.com/albums/af148/timbhp/004-2.jpg)
in this shot you can see eng support which is adjustable for chain tension, seat mount,and side bracing
![](http://i1002.photobucket.com/albums/af148/timbhp/002-2.jpg)
no all that tubeing is not to be welded on to kart, thats a custom cages roll cage for my other project v8 escort cosworth which will be out later this year i hope,
![](http://i1002.photobucket.com/albums/af148/timbhp/005-2.jpg)
in pic repositioned gear leaver boss, and you can see gear leaver linkage going to gear box
![](http://i1002.photobucket.com/albums/af148/timbhp/006-2.jpg)
old rad mounts cut off old chassis as paterns to make new items
![](http://i1002.photobucket.com/albums/af148/timbhp/008-2.jpg)
new rad mounts with rads in place
![](http://i1002.photobucket.com/albums/af148/timbhp/007-2.jpg)
front shot of rads :thumbup1:
well thats it for a week,as kart is now stripped
chassis is at powder coaters
body work is at body shop, wait till you see the new paint sun glasses may b needed
seat at trimers
then when i get it all back it will leave my only 10 days to put together wire up and get running and sort out any last min problems which always turn up to make life entertaining,
so pics of parts when they come back next week.
bush in place
with nice momo bit
offered up in place
both rads
body work ofered up
![](http://i1002.photobucket.com/albums/af148/timbhp/029-2.jpg)
brakes
all pedals fited
seat at trimers
#44
Lucifer II - 666
#45
kart won't be able to make pod ,as wont get chassis back from powder coater till sat ,panels hope they are back for week end? seat next week,
so will just make track day,but im looking forward to smokin the tyres and see what times i can put up,
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
#47
Lucifer II - 666
up........
painted panels all back ,along with powder coated chassis
![](https://i1002.photobucket.com/albums/af148/timbhp/001-3.jpg)
![](https://i1002.photobucket.com/albums/af148/timbhp/002-3.jpg)
couple of pics of powder coated chassis
![](https://i1002.photobucket.com/albums/af148/timbhp/005-3.jpg)
some more parts from powder coaters
![](https://i1002.photobucket.com/albums/af148/timbhp/003-3.jpg)
some of the bolts ,and heat sheild ready
![](https://i1002.photobucket.com/albums/af148/timbhp/004-3.jpg)
new floor pan along with more bits
![](https://i1002.photobucket.com/albums/af148/timbhp/006-3.jpg)
some of the biger bits waitin
![](https://i1002.photobucket.com/albums/af148/timbhp/007-3.jpg)
plus a few on the shelf as well
![](https://i1002.photobucket.com/albums/af148/timbhp/008-3.jpg)
new the cossie would come in for somethin supportin front of chassis till get engine in chassis
![](https://i1002.photobucket.com/albums/af148/timbhp/009-2.jpg)
engine in place
![](https://i1002.photobucket.com/albums/af148/timbhp/010-1.jpg)
exh on along with upper heat sheild mount and engine upper mount
![](https://i1002.photobucket.com/albums/af148/timbhp/011-2.jpg)
in this shot you can see rose joints on engine mount rods this will alow to tension chain
you can also see lower heat sheild mounts
![](https://i1002.photobucket.com/albums/af148/timbhp/012-2.jpg)
rear shot with rear bumper bar
![](https://i1002.photobucket.com/albums/af148/timbhp/013-2.jpg)
new air filters
![](https://i1002.photobucket.com/albums/af148/timbhp/023-3.jpg)
shot from front
![](https://i1002.photobucket.com/albums/af148/timbhp/018-2.jpg)
another rear shot
![](https://i1002.photobucket.com/albums/af148/timbhp/017-4.jpg)
drive chain and brake disc and centre axle support to stop axle bowing with power
![](https://i1002.photobucket.com/albums/af148/timbhp/024-3.jpg)
heat sheild on along with both rads and link pipe work
side shot of rad
![](https://i1002.photobucket.com/albums/af148/timbhp/026-3.jpg)
![](https://i1002.photobucket.com/albums/af148/timbhp/027-3.jpg)
couple of shots of carbon race can fited
more updates when further on :thumbup1:
![](https://passionford.com/forum/images/smilies/smile071.gif)
engine in place
new air filters
shot from front
another rear shot
side shot of rad
#50
Lucifer II - 666
BIG day tomorrow as we have sprint track booked for the whole day!!!
pic's n vids later in the week
#56
Lucifer II - 666
curborough track, was a good day but rained after lunch so there was only a coule of laps out in it this morning with Tim at the wheel.
goes well lol
pics n vids soon.
goes well lol
pics n vids soon.
#57
Lucifer II - 666
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000132.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000133.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000134.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000135.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000136.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000137.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000138.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000139.jpg)
![](https://i227.photobucket.com/albums/dd51/k__boom/P1000140.jpg)
awsome bit of engineering, what a machine it's turned out to be!!!!
Monster Kart eat your heart out, this is how the brit's do it!!!
#59
neeeeeeeeooowmmmm
Why have you got the brake/throttle one the same side and cut out? I'd of had the brake one side, accel. the other, and clutch in the middle like on gearbox karts as you only need the clutch to start/stop. could have had full size pedals then, wouldn't trust braking hard with that one :/
#60
Lucifer II - 666
you also need the clutch for a lot more than stoping and starting in this, clutch control is needed when launching and pulling away so having it at the same foot as the throttle would be a ightmare.
#61
neeeeeeeeooowmmmm
By in the middle, I meant like some gearbox karts, where the pedal is by the nassau panel, and stretches both sides so you can use it with either foot. Should have explained that better too
#66
Looks great now.
Bit of an awkward 1 with the brakes and throttle. You need the brake on the opposite side to the clutch for going down gears i know but it looks awkward.
#67
Lucifer II - 666
lol yes still for sale and just to remind people it isnt mine its my good friends go kart
I had nothing to do with building it only smashing it a year ago which led to this new one being built lol
still for sale if anyone is interested - would like £3750 if you interested.
#69
Lucifer II - 666
![Name: DSCF4556.jpg
Size: 151.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/128522d1501884623-gokart-rebuild-gsxr-1000cc-finished-vid-now-added-also-for-sale-3750-dscf4556.jpg)
![Name: DSCF4557.jpg
Size: 146.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/128523d1501884623-gokart-rebuild-gsxr-1000cc-finished-vid-now-added-also-for-sale-3750-dscf4557.jpg)
![Name: DSCF4558.jpg
Size: 92.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/128524d1501884623-gokart-rebuild-gsxr-1000cc-finished-vid-now-added-also-for-sale-3750-dscf4558.jpg)
![Name: DSCF4559.jpg
Size: 146.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/128525d1501884623-gokart-rebuild-gsxr-1000cc-finished-vid-now-added-also-for-sale-3750-dscf4559.jpg)
#71
Lucifer II - 666
lol heres one for you -
http://www.youtube.com/watch?v=oxxnFzVfulg
![](https://passionford.com/forum/images/smilies/roi.gif)
also now for sale - £3750
£7500 in parts amd materials alone to build not including labour Tim put in building this.
#72
Lucifer II - 666
Lucifer II - 666
it's been around a while enit
if it doesnt sel quick the kart will probably be going to shakespear race way or pod whichever comes up first for some more fun.
#77
Lucifer II - 666
Long gone pal.
DixieTheKid
11
06-06-2020 11:20 AM
