Mk6 JWRC fiesta cosworth
Old 28-03-2012, 09:33 PM
  #2281
Luca
Lukesville
Luca's Avatar
need to fit a new column set up in the car, so tube bearings etc.
Old 01-04-2012, 10:15 AM
  #2282
M K
M K's Avatar
Il have a look and see what I can find for you mate
Old 01-04-2012, 10:16 AM
  #2283
M K
M K's Avatar
Thanks mate
Had a day round garage tinkering, all small jobs lately due to funds being low
Fitted the brake light banjo bolt switch to the pedal box, it's neater and more reliable the the standard push type switches which require a bracket off the pedal etc
Also cut down the push rods slightly so I could angle the pedals back more as they were pointing towards the floor, now they are exactly vertical,
I think I will now move the seat back a little and buy a steering wheel with a deeper dish but that will be trial and error when the cars running so I can find the position I am happy and comfortable with.
I finished fitting the electric power steering pump and hoses to bulkhead
I could not stretch the power steering hose over the return on the pump due to the steel wire braid inside so had to use a double male hose reducer barb and some larger fuel hose to step up the hose size to suit the pump, not the neatest but it works and most will be hidden behind the foot rest when it's done.
I got hold of a galaxy cam sensor with the 90 degree plug to clear my bulkhead, the sensor depth is the same but the o'rings section is smaller diameter so I am getting a modified version of the original billet holder made on a cnc mill,
Here's the new sensor
Here's the original wrc to show size difference
The 2 sensors side by side
Decided to finally properly fit the bonnet and boot pins,
So adjusted to the correct height needed and locked the pins in place
Gaz had already drilled the fronts and used the self tapper screws to hold them temporarily, so I removed them and lined both sides up so they were symmetrical, OCD
Then drilled the holes and painted the bare metal then riveted them in place
Then the same was done with the rear, although I was unable to line the boot lid perfect due to the uneven moulding of these jwrc panels, although its pretty well aligned,
Good to see the car back on its wheels, forgot how awesome it looks
Brings back so much enthusiasm seeing it like this
Old 01-04-2012, 10:27 AM
  #2284
gus
gus's Avatar
looks friggin awesome chick
very very nice indeed
Old 01-04-2012, 10:33 AM
  #2285
COCHYN
COCHYN's Avatar
Epic!
Old 01-04-2012, 10:51 AM
  #2286
massivewangers
massivewangers's Avatar
Looks fantastic on it's wheels, bet you're itching to have a go in it now!
Old 01-04-2012, 11:20 AM
  #2287
chettle
chettle's Avatar
Ive been watching this from the start, bloody awsome build! Attention to detail is epic! gonna be a truely awsome motor when its done!!!
Well done!!!
Old 01-04-2012, 11:28 AM
  #2288
graham c
graham c's Avatar
awesome
Old 01-04-2012, 11:42 AM
  #2289
COLEYST200
COLEYST200's Avatar
Its all looking good mate when i did this mod to the triger i made a sleve to fit over first off so i could make shower it worked which it did so then i made some new holders that would do the job for me and the uver lads that are doing this to there FOCUS COSWORTHS
Old 01-04-2012, 12:47 PM
  #2290
olek
olek's Avatar
just awesome!!
it's this kind of attention to detail that makes a car properly reliable!
do it once, do it right!
Old 01-04-2012, 04:56 PM
  #2291
lanfire
lanfire's Avatar
that looks 100% mean ! love it mate
Old 01-04-2012, 06:11 PM
  #2292
McGlinchey
McGlinchey's Avatar
just read throught all 58 pages.. your a very talented man!!! good luck with the rest of the build
Old 01-04-2012, 07:56 PM
  #2293
matman
matman's Avatar
Epic!!!!!!!!!!!!
Absolutly amazing!!!!!!!!!!!!!!!!!!!!!!
Old 01-04-2012, 11:48 PM
  #2294
stu21t
stu21t's Avatar
I love this car, one of my favourite on here!
And i love the way you work. Im very similar but to a tighter budget than you lol.
Old 02-04-2012, 06:12 AM
  #2295
whizzisat114
whizzisat114's Avatar
Glad the sensor worked out for you
I knew it would as it was just what I needed for mine
Loving the attention to detail
Gonna be one awesome car when finished
Old 02-04-2012, 06:14 AM
  #2296
fezzajsy
fezzajsy's Avatar
looks stunning
Old 02-04-2012, 11:06 AM
  #2297
Sticky.
Sticky.'s Avatar
That looks awesome Marc.
Old 02-04-2012, 11:09 AM
  #2298
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Wow, loving that mate!!!
Old 02-04-2012, 06:21 PM
  #2299
xan_lee
xan_lee's Avatar
Old 03-04-2012, 10:59 AM
  #2300
frayz
Boost Junkie
frayz's Avatar
Such a beautiful build... attention to detail like it should be.
Old 06-04-2012, 08:41 AM
  #2301
M K
M K's Avatar
Thanks for all the praises on the build guys, makes it all the more worthwhile reading this
Update for this week, again only small jobs
Popped to the breakers yard Tuesday to get some door seals and clips etc and while I was there I g a mint ford badge for the boot, so got that stuck on and re fitted the high level brake light and the loom for the light and plate lights
My mate tig welded my wastegate back together where I had tacked it, he had to do a large weave weld as I cut it so close to the original weld it looked crap with 2 welds side by side
Now clears everything ok, just hope the turbo clears when I get 1!
After meaning to do it for ages I finally got the 3m tape out and stuck the door trims back on
Also properly bolted down both seats, had to wait to get some 10.9 high tensile hex head bolts as there is no access for socket caps and I can't bolt the brackets in first as the tunnels side of the seats is too tight to bolt in after so hex head was the only option, I couldn't get a 12.9 hex head so I think 10.9 tensile will be enough considering that fia harness eyes are only 8.8 tensile
Anyway seats now properly fitted and both harnesses fitted properly to the harness bar
Your notice the dash in the second pic but not 100% sure if I am gonna run a dash yet, just fitted it to have a quick look,
That's it for now, tomorrow il have another go at the dash and I am going to bond in the roof vent as I picked up a new mastic gun yesterday after my last broke
Old 06-04-2012, 09:38 AM
  #2302
massivewangers
Looking great there Marc, really starting to look complete now!
I'd definitely run the dash. Get it flocked and it will look great. I think cars look bloody stupid without a dash in them, really unfinished.
Old 06-04-2012, 09:45 AM
  #2303
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
People tell me that i'm a bit OCD about the 'fit and finish' of my track car, but the more I look at yours, the more I think mine is substandard
Its a real credit to you Marc, keep up the good work
Old 06-04-2012, 10:45 AM
  #2304
fezzajsy
fezzajsy's Avatar
looks awesome with the dash in..
Old 06-04-2012, 04:50 PM
  #2305
wes
wes's Avatar
Ditto!
Old 06-04-2012, 05:16 PM
  #2306
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
You are going to cry when you get your first stone chip
Old 06-04-2012, 05:44 PM
  #2307
v man
Zee Germans are coming
v man's Avatar
100% use the dash mate
have you thought about flocking the dash
Old 06-04-2012, 06:02 PM
  #2308
macdoodle
macdoodle's Avatar
now it's takeing shape mate it look's fooking brill keep up the good work
Old 06-04-2012, 09:48 PM
  #2309
M K
M K's Avatar
Thanks guys
I have another dash to use after final cutting has been done, and yes it will 100% be flocked, gonna have the day sorting the dash tomorrow so some more pics then,
As for the first stone chip it's innevitable lol so I can live with it
Old 06-04-2012, 09:52 PM
  #2310
Sticky.
Sticky.'s Avatar
Love that pic.
Old 06-04-2012, 09:54 PM
  #2311
Trist
Trist's Avatar
Originally Posted by Sticky.
Love that pic.
Stunning!!!
Old 07-04-2012, 08:47 AM
  #2312
lukefrs
lukefrs's Avatar
this car is unreal!!!!!!!!!!!!!!!!!!its evil on wheels.........
when your sat in the car how do you find the position of the pedal box???iv just bought the same set up for my mk1 focus rs build and only mocking positions up at the moment.
Old 07-04-2012, 10:17 AM
  #2313
NEEDFORSPEED
NEEDFORSPEED's Avatar
wow wow wow !!!
Old 07-04-2012, 03:29 PM
  #2314
M K
M K's Avatar
Cheers mate, it is a proper looker this one, you can tell it means business lol so i have to make sure the engine has a bit of poke once it is done,
As for the pedal box, it seems ok now, i have it as far back as i can and with the seat where it is i think its gonna be ok, but without actually being able to drive the car it is hard to tell exactly,
Thanks for the comments again
Old 07-04-2012, 03:49 PM
  #2315
M K
M K's Avatar
Decided to bond & rivet the roof vent on as best i could, decided not to use tigerseal for the risk of making a mess on the paint so rivets were the weapon of choice with some clear silicone sealant,
Ran some sealant around the movable vent so no water can leak through if im out in the rain
Then drilled the holes around the vent for the rivets
Riveted it in place and dabbed some sealer over each rivet
I forgot the front rivets would be seen so i removed all sealer from them after
As it's not likely to be seen as it isn't often you will look at the roof when in the car ( i hope ) i also ran some sealer around the vent and again over each rivet as i don't want water leaking in if caught in the rain or when the car car gets washed
It doesn't look very neat in the pics as the flash makes it all stand out but from in the car it's very tidy, so im happy with that
Then put the cover back on and voila
Thanks for your opinions on the dash decisions guys, i agree with you and decided i will be running a dash, although it will be a cut down minimal version that will eventually be flocked
I cut a bit more off the dummy dash today and then re fitted it and i think i am happy with how it is now, because this one has been sitting around since Andrew done the car it has gone a bit out of shape, luckily i have a complete mint dash that i will use to cut up once i have made all the trimming mistakes etc with this one,
Here it is fitted with a bit more removed
Not the best pic but you get the idea
Finally today i removed the fuel tank and painted it satin black as plain alloy looked a bit crap,
Bit of etch primer after a key up
Bit of grey high build primer
Then a few coats of satin black to finish it off
And finally re fitted to the car for some pics, it is not bolted in properly yet as i want some foam backing to stick to the underside of the tank to stop any potential vibration etc
Looks much better
Thanks
Marc
Old 07-04-2012, 03:56 PM
  #2316
COCHYN
COCHYN's Avatar
Awesome Marc, but are those seats staying in? Doesn't suit it really, not extreme enough...wanna sell them to me?
Old 07-04-2012, 04:13 PM
  #2317
Sticky.
Sticky.'s Avatar
Another great update Marc.
When you hoping to have it finished?
Old 07-04-2012, 04:21 PM
  #2318
Fudgey
Baby Cheesus
Fudgey's Avatar
great stuff
Old 07-04-2012, 04:28 PM
  #2319
LIMITLESS
LIMITLESS's Avatar
Awesome update mate.
Loving this car , attention to detail is second to none
Old 07-04-2012, 05:47 PM
  #2320
whizzisat114
Id paint pop rivets that are showing on roof vent black
Coming on well now Mark
Quick Reply: Mk6 JWRC fiesta cosworth
