Zetec Conversion into MK4...What do I need to change?
Mk4 Escort Estate
I'm in the process of putting a zetec into my MK4 escort estate but need to know what I need to change!! Any help please?
engine mount needs modifying, if its a 2.0l your poss need oil pump, i bvelieve the water pump works the wrong way but not sure so may need to swap to a 18 esc one along with sump and pic up then obv engine loom needs wiring in too. good luck
YES I KNOW I CANT SPELL
your right the water pump goes the wrong way you need one foo a 1.8 zetec like an escort gti one. you will also need a cvh alt bracket and to fit a zetec alt pully with a small spacer
JK12
33
26-04-2021 12:09 PM
grishenko45
09-09-2015 12:58 PM
