PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 24-05-2008, 10:47 PM   #1
fordie2581
fordie2581's Avatar
Trader Score: (0)
fordie2581 is an unknown quantity at this point
Default Escort Zetec turbo build 11 sec 1/4
BUILDING A ROAD LEGAL TRACK CAR
It all started off catching the 1/4 mile bug going to a few pod days in my s2 turbo.
Turning out to be a stripped out second car which spends most of its life in my garage in
bits but i have managed to have her round Silverstone and get in plenty of 1/4 mile days
with my best time being 13.6 with 195bhp and 224lbs/ft.
spec
1.6 standard bottom end
standard head
standard turbo
Kent 36 cam kit and pully
Apexi boost controller
Omex rev limiter
Collins ecu
Mitsubishi Evo 4 intercooler
CTS stage 2 plus box
AP 4 paddle clutch
light and balanced fly wheel
Gaz coilovers
Scorpion full system 3"
Car weight = 820kgs
I was thinking about breaking it and laying off the car scene for a bit but couldn't bring myself
round to do it so now i'm going full out for a Zetec Turbo 1/4 mile bute hoping to get her into
the 11's but we'll see how that goes!
Zetec Turbo parts so far:
Zetec silvertop lump
JE Pistons
Eagle rods
ARP bolts. head, main, flywheel, con rods
Alloy bottom pulley
Nissan 480cc injectors side feed
RS 1800 inlet
Exhaust manifold
Nos
omex 710
Tial 44mm wastegate
new JE pistons, i'm gonna be running a 9 comp on my Zetec build. I know a lot of people run a
low comp and more boost but i'm going for a 14-18 psi and 100 shot of NOS to help me out.
These pistons are supposed to be rated 900bhp and 300 shot of NOS - we'll see how that holds
out.
CTS Stage 2 plus box with Quaife ATB, i ended up buying this box due to my nature of driving -
i got through 2 standard RS Turbo butes. So i thought instead of wasting my money keep buying
boxes, oil and the hassel of keep swapping them so i went out and bought this one new from Bernie
himself as i heard a lot of good things about the boxes and i must admit i've had no problems with it
apart from it weeping oil out of the cover plate and it did bring my times down on the 1/4.
Intercooler -
Fun and games i had here, started off with buying a Pace double capacity one, you can just see it in
the pic at the top of me going down Santa Pod. Thinking these were supposed to be good, it wasn't
until i got myself an ACT gauge that i noticed that temperatures were indeed going into the 70's which
is very bad. I don't know if anyone else has ever had this problem but i found it sat too close to the
radiator. So i ended up coming across a standard Mitsubishi Evo 4 intercooler, it was a bit of a mission
to fit but was a decent size, not going to big and has plenty of room away from the radiator and the
temperature has not yet gone over 34 and that was when it was on a rolling road although I know
they use big fans to keep the temperature down. I'm really happy with it. We'll just have to see if it's
any good for the zetec!
Inlet -
I'm gonna be using the cast zetec inlet off of the 1.6 and 1.8 - i don't know if there is a difference
between the two but i have bought the 1.6 and can't see there being a difference. I'll be using side
feed injectors, i've seen they're making higher flow injectors for these now but you can also use Nissan
ones, not too sure which ones i'll be using yet but think i'll be going for 550cc ones of some sort.
update
Due to help from luke89 i found out that there is a lot of difference between the inlet manifolds so
now i'll be scrapping my 1.6 and going for the RS1800.
sump
I've got the zetec 1.6 sump so i can run the exhaust in the same place as a cvh engine would but
what i'm wondering is there any difference between the 1.6 and 1.8 sumps i.e. capacity
fordie2581 is offline   Reply With Quote
Old 25-05-2008, 12:25 AM   #2
Red16
Trader Score: (0)
Red16 will become famous soon enough
Send a message via MSN to Red16
11s 1/4 mile in a fwd Escort is a tad optomistic imo
good luck in trying tho, be nice to see your project as it progresses, keep the pics and updates coming
__________________
Mac Motorsports Worx ZX10r turbo engined kit car... build thread in the restorations, rebuild & projects section
PS3 username - SausageArm ....... My DSLR photo's - http://www.flickr.com/photos/30990332@N02/
Red16 is offline   Reply With Quote
Old 25-05-2008, 12:28 AM   #3
MD Cos
Zetec Turbo Escos
Trader Score: (0)
MD Cos is an unknown quantity at this point
Send a message via MSN to MD Cos
nobody has managed 11s in a fwd ford in this country as far as i know... but a work mate of mine has in a vauxhall, so its seemingly possible
__________________
Escort RS Cosworth project underway!
MD Cos is offline   Reply With Quote
Old 25-05-2008, 08:50 PM   #4
rst-g
ZETEC TURBO
rst-g's Avatar
Trader Score: (0)
rst-g is an unknown quantity at this point
Send a message via MSN to rst-g
get more pics off the motor!!!!
rst-g is offline   Reply With Quote
Old 25-05-2008, 10:37 PM   #5
jonnyrsturbo
is half man, half amazin'
Trader Score: (0)
jonnyrsturbo is an unknown quantity at this point
looks sweet as that 1 mate
jonnyrsturbo is offline   Reply With Quote
Old 26-05-2008, 10:30 AM   #6
luke89
Team HOTHOT!
Trader Score: (1)
Location: Reading, Berkshire Drives : 2.0ltr fez .. when it works
luke89 is an unknown quantity at this point
Send a message via MSN to luke89
just some info for you on the inlet that could save u some bother ! ,
all the zetec inlets are diffrent
1.6 90ps
1.8 105-150ps
1.8 130ps + rs1800
the rs1800 one has the biggest ports and is also slightly diffrent in shape,
also the rs1800 tb is the same size as a 2.0ltr zetec one ,
i have got a rs1800 one for my zt and one on my 2.0ltr zetec at and theres a lot of diffrent from when it had the 1.6 one on !
not the best pic as its old but you can see the port size diffrents !
hope thats some help
__________________
lambo green audi tt 265bhp 4x4 umm
GPtuning
luke89 is offline   Reply With Quote
Old 26-05-2008, 10:41 AM   #7
McGoo 69
McGoo 69's Avatar
Trader Score: (0)
McGoo 69 is an unknown quantity at this point
Send a message via MSN to McGoo 69
looking good mate, gonna be sweet
as already mentiong there is a difference between the inlets, go for the rs1800 one
McGoo 69 is offline   Reply With Quote
Old 26-05-2008, 10:51 AM   #8
fordie2581
fordie2581's Avatar
Trader Score: (0)
Thumbs up
thanks for your help and putting me right on the inlet front, first change to my project.
Cheers dude
Old 26-05-2008, 12:45 PM   #9
gareth231
Trader Score: (0)
gareth231 is an unknown quantity at this point
good project dude - wont be as fast as mine
gareth231 is offline   Reply With Quote
Old 26-05-2008, 02:31 PM   #10
luke89
Team HOTHOT!
Trader Score: (1)
for sump capasity theres no diffrance, just the 1.6 si one has a bolt hole lol
__________________
GPtuning
Old 27-05-2008, 09:54 AM   #11
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Nice project mate
Keep us up dated
Brian
__________________
Brian is offline   Reply With Quote
Old 27-05-2008, 12:09 PM   #12
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Trader Score: (1)
Charlie Chalk is on a distinguished road
Send a message via MSN to Charlie Chalk
11's, on what suspension?
Tims got over 300+bhp and can't get into 11's, and his suspession set up is pretty good.
Good luck anyway, Will watch this
__________________
GE - 1D - T
Charlie Chalk is offline   Reply With Quote
Old 27-05-2008, 01:02 PM   #13
NEWTON
Trader Score: (0)
NEWTON is an unknown quantity at this point
looking good
NEWTON is offline   Reply With Quote
Old 27-05-2008, 10:01 PM   #14
fordie2581
fordie2581's Avatar
Trader Score: (0)
I'm running Gaz coilovers all round on about 290lb springs. She's also stripped out and weights only 820kgs
Old 28-05-2008, 10:06 PM   #15
turbotoaster
turbotoaster's Avatar
Trader Score: (0)
turbotoaster is an unknown quantity at this point
Send a message via MSN to turbotoaster
ever wonder why no ford can get into the 11s when renault 5s can do it with 260bhp, its call tires, dont buy 888 and think they are amazing because they are track tires not drag tires, get some hoosier or M&T tyres and ur laughing, i guarantee tim could run a high 11 easy with proper tyres
__________________
It's a basic truth of the human condition that everybody lies. The only variable is about what!
turbotoaster is offline   Reply With Quote
Old 29-05-2008, 06:53 PM   #16
fordie2581
fordie2581's Avatar
Trader Score: (0)
Smile
Old 31-05-2008, 06:23 PM   #17
fordie2581
fordie2581's Avatar
Trader Score: (0)
Default loom
Started on the loom today and finished cutting out what i didn't
need. To be honest it was a lot easier then i thought. Kept
lights,fan,alternator,wiper things like that - and they still work.
Old 31-05-2008, 06:32 PM   #18
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
pa_sjo is an unknown quantity at this point
What differential do you intend to run? 11's is quite the target!!
__________________
Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo.
pa_sjo is offline   Reply With Quote
Old 31-05-2008, 11:51 PM   #19
fordie2581
fordie2581's Avatar
Trader Score: (0)
Quote:
quaife ATB . i no it will be hard.
Old 01-06-2008, 05:22 AM   #20
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
I think you'd probably want something a bit more specific for drag racing!
__________________
Old 01-06-2008, 09:23 AM   #21
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
Good work mate keep going you will get there
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
Old 01-06-2008, 10:34 AM   #22
luke89
Team HOTHOT!
Trader Score: (1)
what else are u goin to help with traction ? drag bars on the rear to lock it out at full rase ? wide front tyers , skinny rears ? un sprong weight is something to think about to ! some sort of drop limmiter on the front to hold it down and stop it from liftin ?
__________________
GPtuning
Old 01-06-2008, 10:43 AM   #23
Chip
*** Sierra RS Custard ***
Chip's Avatar
Trader Score: (3)
Chip will become famous soon enoughChip will become famous soon enough
Quote:
Doing it on slicks just isnt impressive at all, 11s is a fast road car, its a very slow drag car though.
Quite a few vauxhall lads in the 11s in fully road legal trim running 888 and similar tyres.
__________________
Sometimes its more fun not to care if things make sense, and just do them anyway!
Vauxhall Nova, Mid Engined, RWD, 457bhp, Autronic SM4, GT35R, Quaiffe ATB Diff
2.0 16v - DIY Specced, DIY Built, DIY Mapped, DIY Abused
www.VauxSport.com
Chip is offline   Reply With Quote
Old 01-06-2008, 10:43 AM   #24
XRT_si
Trader Score: (2)
XRT_si is an unknown quantity at this point
Tim is on stret legal drag radials i.e. The BEST street legal tyres you can possibly get
There are Renault 5s running 11s with street legal tyres too, anything else is cheating imo.
It will be quite a mission to run an 11, but good luck to you. By the way, a Quaife ATB is NOT the best diff to run for drag racing. Far from it in fact.
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far...
Classic Fords FTW!
XRT_si is online now   Reply With Quote
Old 03-06-2008, 08:34 PM   #25
fordie2581
fordie2581's Avatar
Trader Score: (0)
Old 08-06-2008, 06:17 PM   #26
fordie2581
fordie2581's Avatar
Trader Score: (0)
Old 11-06-2008, 08:22 PM   #27
gareth231
Trader Score: (0)
sent you a pm dude
Old 12-06-2008, 02:30 PM   #28
Tim
Tim's Avatar
Trader Score: (1)
Tim is an unknown quantity at this point
Best of luck with the build but i think you need a re think on your times , hope u get close.
tim
__________________
Built By Norris Motorsport.(Builders of the worlds fastest RS TURBO'S).
www.norrismotorsport.co.uk 01773 836274
Tim is offline   Reply With Quote
Old 13-06-2008, 12:42 PM   #29
Fiesta_ie
Sandpaperman in acction
Trader Score: (0)
Fiesta_ie is an unknown quantity at this point
welded diff maybe better and cheep ;P
Fiesta_ie is offline   Reply With Quote
Old 15-06-2008, 04:29 PM   #30
RSturboJET
Can't Find 'em? Grind 'em
RSturboJET's Avatar
Trader Score: (0)
RSturboJET is an unknown quantity at this point
What is the part no. on the RS1800/130p.s. inlet manifold? I heard all 1.8 inlets are the same except the plastic mondeo/escort/focus ones.
__________________
Mk3 Fiesta 2L Zetec
RSturboJET is offline   Reply With Quote
Old 15-06-2008, 06:04 PM   #31
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Trader Score: (0)
They're visibly different (even though a lot of morons will argue that ), however I don't have the part number to hand i'm afraid. Post a pic and I can tell you which one it is.
__________________
Old 15-06-2008, 07:56 PM   #32
luke89
Team HOTHOT!
Trader Score: (1)
my rs inlet is away being polished , but all efi inlets with HO on the back casted to the drivers side of the inlet , so if your lookin at from the back its on your right is a rs1800 1
__________________
GPtuning
Old 21-06-2008, 07:04 PM   #33
Maximum Hustler
Maximum Hustler's Avatar
Trader Score: (0)
Maximum Hustler is an unknown quantity at this point
Nice project
__________________
Maximum Hustler is offline   Reply With Quote
Old 28-06-2008, 04:07 PM   #34
fordie2581
fordie2581's Avatar
Trader Score: (0)
Engine is built now, using Focus RS head gasket, 1.8 Escort Zetec water pump, 1.6 Zetec sump, 2.0 Zetec cams and all performance parts i've mentioned before. Compression ratio worked out to be 8.8.1 lower than the 9.0.1 i was going for. Not sure what the dynamic ratio will be yet.
Old 04-07-2008, 10:02 PM   #35
rsturbo-2008
Trader Score: (0)
rsturbo-2008 is on a distinguished road
hello mate told u i would look at some point u need more pics of your engine and bits so i can rob all of your ideas talk to u in a bit
rsturbo-2008 is offline   Reply With Quote
Old 30-07-2008, 09:07 PM   #36
fordie2581
fordie2581's Avatar
Trader Score: (0)
Engine mount sorted, don't look the prettiest but fits spot on
Exhaust manifold arrived, got from the US. No doubt you have seen and heard about these. I have heard a mixture of views on these, good and bad. The only way to find out is to test it
Old 30-07-2008, 09:54 PM   #37
Roosie
500bhp Cosworth in making
Roosie's Avatar
Trader Score: (7)
Roosie is an unknown quantity at this point
Send a message via MSN to Roosie
really impressed with this thread well done
Roosie is offline   Reply With Quote
Old 31-07-2008, 12:27 AM   #38
XRT_si
Trader Score: (2)
Manifold looks good mate.
__________________
Classic Fords FTW!
Old 31-07-2008, 12:52 AM   #39
Dan F
Dan F's Avatar
Trader Score: (0)
Dan F is an unknown quantity at this point
Daniel Fitzpatrick WTF Stringbean FRANKOWL86
Send a message via MSN to Dan F
Cool project fella,hope you do manage to get into the 11's,if not then have fun trying
__________________
Dan F is offline   Reply With Quote
Old 31-07-2008, 12:56 AM   #40
Chip
Chip's Avatar
Trader Score: (3)
Coming along nicely, although I still doing think you will break below the 12s on normal road tyres personally, lol
__________________
www.VauxSport.com
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Zetec turbo build help RS Bungle General Car Related Discussion. 14 21-12-2008 04:20 PM
zetec turbo build smitsturbo Ford Escort RS Turbo 3 12-07-2006 06:47 PM
Zetec Turbo build thelynx Ford Escort RS Turbo 6 07-02-2006 02:10 PM
zetec turbo build escygti Restorations, Rebuilds & Projects. 0 09-01-2006 11:05 PM
My 2.1 Zetec Turbo Build Roosie Restorations, Rebuilds & Projects. 42 15-12-2004 06:08 PM
