Boost control - Talk to me
Ok, probably getting ready to think about boost control, the car is an escort cosworth and I am in no way nostalgic in thinking I need to have air injectors, of in the case of the WR cars twin air injectors, so what is the options, something bleed off, fast solenoid that I can control, nice quick PWM.
How about one of these
http://www.ebay.co.uk/itm/3-Port-Ele...item2ecd67bcef
Good ? yes?
What have you used? (and did it work - please nothing manual)
Good ? yes?
Im using one with L8 ecu and working good.Was easy to take control of the boost when turbo surge.
Good ? yes?
Good ? yes?
markk (06-09-2015)
Good ? yes?
Good ? yes?
Cheaper seller albeit US.
http://www.ebay.co.uk/itm/MAC-Boost-...item4d2462b654
Some others prefer the Pierburg, which apparently is a little faster than the MAC.
http://www.garagewhifbitz.co.uk/inde...-solenoid.html
I can see no reason to go with the expense and complication of air injectors.
after using a amal valve on my race car with poor results (boost would sway 3/4 psi until at high rpm)
I moved onto a single MSD air injector and it transformed it, perfect boost control giving me the exact boost required every time, can't recommend it enough
a fit and forget solution
steve
steve
If the ecu is capable of PWM'ing the output, then yes it can use a 3 port solenoid.
Likewise if it can drive air injectors, then it could also run the solenoid instead.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
