Starting a car after a long time
8 Fords and counting...
Hey guys,
My MK4 Escort xr3i cabriolet hasn't been started for almost three years now.
I kept it garaged as I neither had the time nor the money..
Can I just start it up as usual after charging the battery and topping up oil and cooling liquid or is there anything I should be cautious of?
Fox
Fox
Being a cvh I'd change the cambelt before u do anything. I expect the fuel will be stale so drain the tank and put fresh fuel in, change the engine oil also. Turn the engine by hand just to make sure it isn't stuck/seized etc. disconnect the king lead off the dizzy and turn it over untill oil pressure light goes out then wait to see if the light comes back on when oil pressure drops. Then re connect king lead and give it a try
Archiejay
12-08-2015 12:07 PM
sridgett
15
03-08-2015 07:26 PM
CabrioTurbo
01-08-2015 11:04 AM
