Autronic sm4 questions...
Have recently purchased a second hand (basically brand new) autronic sm4 ecu and ryan car looms uk full engine loom for a yb. It is literally just the ecu and loom.
I have a few questions regarding the intstallation..
Do i use all existing sensors or do i need autronic specific items? If i need sensors, where can i purchase them and what ones do i need?
Do i need boost control or is it internal to ecu?
Map sensor is internal right?
Do i use standard ignition amp?
Do i use standard crank sensor?
As said, all i have is ecu and loom, is there anything else apart from coilpack and leads that anyone knows i need to buy also?
Thanks in advance.
Mitch
Thanks in advance.
Mitch
Thanks in advance.
Mitch
Thanks in advance.
Mitch
4.4bar mapsensor internal to ecu,
It will use a bosch Ign map,
Standard crank sensor.
Mark
Focosmitch (23-02-2015)
Ok, today i have oredered..
Autronic airtemp and water sensors.
Motorsport developments coilpack and leads
Mac valve
Anybody have a part number or link to the bosch ignition amps?
Im assuming the autronic sm4 has a ignition amp internal also as my loom only has 1 plug for ignition amp and it needs 2 amps to run msd/zetec coil pack right?
Mac valve
Mac valve
Mac valve
Happily retired
Mac valve
Mac valve
I almost asked at the start make sure your loom is correct for the coil combo you are going to use, I produced at least 5 different ones for M.A.D. The looms were always custom made to the car as there are a fair few differences in plug positions across all head/Block/Coil combo's.. Also wiring differences between Big/Small Turbo.
Mark
ImaRacing 700
74
21-03-2005 09:48 PM
ImaRacing 700
107
29-01-2005 06:54 PM
