autronic versus level 8
#81
Colossal Pervert
#82
*** Sierra RS Custard ***
4 teeth instead of 2, but that really doesnt matter, getting updated twice per revolution (once per cycle) is plenty for the ecu to know where the crank is at all times, as it projects an exact value based upon the last known position and speed (as does the L8)
#83
Testing the future
it's not always exact if it's projected is it? but close enough
#84
Dont know about the internals of the Autronic but I would have thought it would be better.
As an example, my own design ecu had a resolution of 0.042 degrees @10000 rpm
Good resolution but, it doesnt make much difference in the real world. !
Having said that, 0.25 degrees is a very small amount and most tuners tend to stick to the nearest whole degree most of the time when mapping or halves at critical points.
Also, while a crank is at a constant speed from your perception, in fact its actual RPM is fluctuating a small amount positive and negatively.
To keep the software stable, all ecu's will measure the rpm and average out the value in order to smooth out operation.
This smoothing inherently leads to loss of crank resolution anyway. !
Fuel map resolution size makes little difference too.
No matter how small the maximum values are, the interpolation between the 4 points in a map wil always be calculated at a significant numeric magnitude higher before pasing the final pulse width value to the fuel injector.
What does affect resolution is setting the mapping scaling to the right size of fuel injectors.
Hope this makes sense ...LOL
#87
Colossal Pervert
That's all good and well, but my point still stands, Weber is 'more' accurate at measuring the crank position as it has twice as many pick up points on the trigger. Any smoothing/predictive algorithm will be relying on frequency of input to provide a 'more accurate' calculation
#89
I would think the autronic at least has over twice the "look ahead timer" clock speed so less samples are needed.
In other words, it pretty much cancels out when comparing these 2 set ups.
#90
Colossal Pervert
#92
Mark,
More teeth will increase the overal accuracy to a point but all samples from a complete resolution are added up to proved the same total value in any one RPM.
This is true no matter how many teeth there are, you get the same value. !
More teeth does allow decel and accel rpm fuel enrichment to be more accurate
True ecu resolution is defined by the bit (or word) size of the time processor master clock frequency and how the software takes advantage of it.
Hard to explain in laymans terms but even a high resolution clock will only have a big advantage when using large injectors and very small numbers in the fuel map.
Most tuners scale the map (by default) to the max range of available fuel pulse time.
For the record I am in no way dissing the Autronic but the L8, old it maybe but it can still hold its own these days.
Access to mapping the L8 is its biggest dissadvantage to the L8 but if someone else is doing the mapping ... that doesnt matter.
#94
Also check what lugs are removed when using a Autronic on the stock 4 lug pully,
Yes 0dg and 180dg which at this point the ecu has already fired and the 90dg and 270dg are the ones that tell the ecu where it is,
I guess Simon should be able to correctly tell us how important the lost lugs are,
I could easly change to 36-1 on them all, BTW Rods runs 2 lugs at 60dg lead angle.
Mark
#96
Evening everybody
I can see this thread getting very technical and way above my understanding of the inner workings of ecus,thats not to say i dont find it interesting just a little over my head.
The car was bought as a project and i would like to put the best i can afford into the car,it just means the rebuild will take a little longer should the consensus of opinion be that autronic is the way forward.
#97
i would take your location as a bit of a guide are you near a good tunner that do good deals as the performance ecu will be more difficult to get up and running and may need calibrating to your standards a couple of times etc... i always run near the 400bhp mark so i think its just so easy to just order chips from msd put it in off you go.. have a quick and cheap check on a local dyno. and forget about it.
i know i could probly get 10more bhp from a live map but i cant be arsed to drive hundereds of miles to a tuner costing loads on fuel and pay my mates petrol to give me a lift there and back and the live map fuel and the live map cost.. i reacon probly Ł800 in total i would only be interested if i was running 450bhp+
sos just my opinion. Ł800 is alot of money.....
#99
Oh dear, it didnt take long for someone to have a dig at me, just didnt expect it to be you ...
Maybe true but you can get an L8 with all bits ready to go or upgrade the one that you may already have !
That isnt the point though, I personally would choose Autronic over L8 myself given a big budget thats all I was getting at.
Not everyone can afford one or actually needs one !
You dont need an expensive ecu to get big power or to make it drive nicely,
The setup and attention to detail is the key... Mark is a brilliant tuner but he isnt the only one out there !
#103
Almost there!
ok dude, for some reason i thought you were
Thank you Simon, thats very polite of yourself and ill treasure your warming words after the day ive had.
But seriously mate, see PM - my comment wasnt aimed at you in the slightest
#104
dom 123
to tell you the truth i am not aware of any good cossie tuners in the south of ireland ,so ulitmatley a quick trip to england would be on the cards.i really would like to have it mapped using the petrol i get locally as i dont fancy melting a piston.
cheers james
cheers james
#110
Having said that, Autronics mapping software can also perfrom data monitoring and diagnostics.
I think they may even have there own dash type program too but not sure !
#111
I appologise 100% for my comments directed at yourself
Thanks for clarifying what you meant and taking the time to do so
I am a cock
#113
Super Moderator
for a cosworth it has to be l8 and P8 as it came free with the cars
replacing ecu's means wiring looms and expense
If cost wasn't an issue it has to be the pectel T6 we also have motec ,life , autronics.
These ecu's are so easy to map compared with OE
Personally I like to pay more for quality and for things to be future proof
#117
tony
thats whats leaning me towards the autronic setup its pretty future proof.
i will have to have a loom made anyway as i didnt get one with the car,and fancy a new or good second hand braided loom just to eliminate any future wiring problems.
cheers james
cheers james
#120
Sponsor
i agree tony but i have 1x6 and 2xl8s in the bin in my garage that have burnt tracks bodged quality repairs and for this reason i wouldnt put a webber ecu on my car let alone so called upgrade to a l8 and then spend a fortune on upgrades ,most webber stuff is over 20 years old and will only get more unreliable as time goes on
