abs relay problems
Old 16-09-2016, 07:03 AM
london_chris
london_chris's Avatar
Default abs relay problems
helping a mate source an abs fault, the abs warning light is on all the time, the wheel sensors are all ok,
gone back to the abs relay, the fuse is fine (20a) attacehed to the relay, power in is fine through the relay, there just appears to be no switched feed to power the relay on and latch it?
anyone come across this fault before?
have read the wiring diagram via autodata and the component test section and the wiring diagram appear to have conflicting information...........
Old 16-09-2016, 07:57 AM
Caddyshack
Caddyshack's Avatar
Cant you run a switched live to the relay as a test? If you can take a pic of the relay and post it up I can see if I still have a spare kicking around to post to you as it might just need a relay swap?
Old 17-09-2016, 08:29 AM
martysmartie
martysmartie's Avatar
I should think that is correct, as the pump does not run continuously and is switched via the pressure switch.
Moreover, if this were faulty you would have no pressure!
How have you determined the sensors are ok?
Martin
Old 17-09-2016, 07:53 PM
doga-ot
wesskitzo
doga-ot's Avatar
If relay is ok it pressure switch fault which is very common, means buying 2nd hand abs mastercylinder/servo as no one will sell switch seperate!
Old 17-09-2016, 08:14 PM
Caddyshack
Caddyshack's Avatar
I have those bits in good condition if you need to buy 2nd hand.
Old 18-09-2016, 07:07 PM
pauloopnorth
pauloopnorth's Avatar
Just a note regarding the pressure switch , I have discovered the P38 range rover uses the same pressure
switch
Old 18-09-2016, 07:12 PM
pauloopnorth
and I think the saab 900 does too but not seen that for myself
Old 18-09-2016, 07:26 PM
costina
Live long and prosper!!
costina's Avatar
Good info there Paul
doga-ot
12
27-08-2017 06:19 PM
Kiezlucas
14-09-2016 12:59 PM
Deakesy
Wheels and Tyres
12-09-2016 09:03 AM
1986rs
22
10-09-2016 08:16 PM
slider
29-08-2016 04:37 PM
Quick Reply: abs relay problems
