Issue with filling Saff with fuel...
Old 30-08-2016, 02:48 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Default Issue with filling Saff with fuel...
Its always done it, but its really doing my head in now!
Try to put fuel in my Saff, and it takes ages and nozzle keeps 'clicking' as if full.
If the tank is nearly empty, I can put £10 or so in with no problem then it becomes a nightmare and literally manage to get a few quid at a time and sometimes chucks fuel back out at you!
Someone suggested the breather on the tank may be blocked? Any experience with this or other suggestions? Tank looks fairly recent although must have been done by a previous owner. Unsure if a genuine or pattern part.
Cheers!
Old 30-08-2016, 03:56 PM
haz87
haz87's Avatar
Takes two minutes to blow through the breather to check if its blocked or not. My Escort suffered similar at the pumps and still does from time to time, but i know my breather is clear.
Just accepted it as character, tho I've never had fuel thrown back at me, the nozzle should stop it overfilling like that. Makes me think your's is perhaps a blocked breather so may be a cheap fix..
Old 30-08-2016, 04:24 PM
furry
DECODING JIBBA JABBA!!
furry's Avatar
will be a blocked breather
Old 30-08-2016, 07:34 PM
rooos
rooos's Avatar
sometimes i have the same problem with my old fiat.
i always solved it by just moving the car to another pump.
it happens me in more than one gas station.
in those cases the problem is a too sensible pump-gun...
.. and i got the bad habit to stop the car near the faulty ones, already knowing and without thinking.
weird thing is: next car, same faulty pump-gun, no problem. (so my breather may not be working so good too)
this fact...
Originally Posted by Zetec_mk4_XR3i
...sometimes chucks fuel back out at you!
suggests it highly likely could be an almost fully plugged breather hose.
good luck with it...
let us know what it really was, once you solved it.
Old 30-08-2016, 08:14 PM
Cos500
Cos500's Avatar
Had this on two of my cossies, as above both were blocked breathers, let us know how you get on
Old 31-08-2016, 07:21 AM
Zetec_mk4_XR3i
Cheers lads, on my to do list then.
Does the tank need dropped to access the breather?
Old 31-08-2016, 03:42 PM
dojj
Resident Wrestling Legend
dojj's Avatar
There are two breathers
One that runs alongside the filter neck
Then another very small one that runs along the outer end of the tank
The filter breather will be clogged more than likely and that's a tank out job
Very easy but don't break anything
Old 01-09-2016, 08:39 AM
j.hammond1
j.hammond1's Avatar
Mine did this after putting on an after market tank. The breather pipe is slightly smaller and I had to modify the hose to fit it on. If yours is a new tank it's probably because of this. It's really annoying so I'm going to find a genuine when I can be bothered to fit it.
Old 05-09-2016, 08:05 AM
Zetec_mk4_XR3i
Thanks lads - on the winter to-do list!
Old 10-09-2016, 08:01 PM
3doorcozmess
3doorcozmess's Avatar
I'll get some pictures up tomorrow
Old 20-12-2016, 07:13 AM
Zetec_mk4_XR3i
Thanks for all your help guys.
Tackled this at weekend and was a lot easier than I expected. The breather pipe on the sender unit was damaged slightly and someone had tried to fix it with silicon sealer...however there was a big splodge of sealer stuck inside the breather. All cleaned out and back on now!
Thanks again!
Old 20-12-2016, 02:01 PM
dojj
dojj's Avatar
see?
easy
McCloud 85
11
05-05-2016 10:47 PM
Tank Mike
08-04-2016 02:36 PM
31-03-2016 08:26 PM
Gooey
Ford Classics & Vintage
32
05-12-2003 01:38 PM
Quick Reply: Issue with filling Saff with fuel...
