Cosworth ecu
Old 22-01-2016, 02:00 PM
jason3249
jason3249's Avatar
Default Cosworth ecu
Hi people
Dont know if this is the right place
I need a ecu for a cosworth management setup on my escort
But theres so many driving me mad
I don't know what to pick from
Is there a guide as i pick one and people say thats no good go for this go for that
Im lost
Can anyone explain or have a guide etc
Thanks all
Old 22-01-2016, 02:23 PM
cozzy jeff
cozzy jeff's Avatar
if your talking webber to run on an rs turbo,then level 1 ecu through to p8 will be fine.
Old 22-01-2016, 03:55 PM
James Mac
James Mac's Avatar
Plenty of info on here
http://www.bigturbo.co.uk
Old 22-01-2016, 04:36 PM
jason3249
jason3249's Avatar
Thanks was looking at a l8 ecu
Just don't get it some are worth more than others
I thought they were all the same just the chips are different
Old 22-01-2016, 07:12 PM
costina
Live long and prosper!!
costina's Avatar
No fucking about a level 8 is what you need.
Its more robust than the P8 and will do most things you require.
Get MSD to live map it once your running job done.
Old 23-01-2016, 08:11 AM
cossynut2
cossynut2's Avatar
You can still run low impedence injectors with the l8 ,like Siemens 55lb or83lb which is good as well.
Old 23-01-2016, 10:04 AM
martysmartie
martysmartie's Avatar
No there not.
L1 and L6 have different electronics, but L8 has double the memory, i.e. 128 KB.
This means it is capable of running functions like ALS, LC, CL etc.
Martin
Old 23-01-2016, 08:42 PM
steppy
steppy's Avatar
I agree I used a l8 on an erst with a chip from oddkid creations, it's worth signing up on his forum he's a very friendly knowledgeable bloke
Old 23-01-2016, 09:33 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Anyone got a list to what ECU is in each year?
For instance what's in my K plate Sapphire out of interest?
Old 23-01-2016, 09:35 PM
steppy
steppy's Avatar
L1 3 door cosworth
L6 2wd saph
L8 4wd saph red label non cat, green label for cat models that had lambda.
P8 escort cosworth
Old 26-01-2016, 10:25 AM
R4N SS
R4N SS's Avatar
I wouldnt even bother running cossie management on a RS Turbo - by the time you add up the costs you will be better off going aftermarket as will have a better ecu with more functions and memory and then get a new loom built rather than using 30 year old wiring.
Omex 600 ecu is Ł600 and loom around Ł250 all brand new.
You will pay at least Ł250 for a L8 ecu then the you need engine wiring loom. Then if you want LC or ALS then its more money. Will work out better for aftermarket
Old 26-01-2016, 10:42 AM
steppy
steppy's Avatar
It's horses for courses, i personally wouldn't entertain something like omex now I've fitted the cosworth management, there are more tuners with many years experience of working with the system that can map it, also the system uses all ford parts so if your anywhere and start having problems the sensors are readily available, I can't recommend it enough, smooth with great power delivery, but that's my opinion
Old 26-01-2016, 12:28 PM
R4N SS
R4N SS's Avatar
Omex uses the same sensors - in fact it uses less sensors which means less to go wrong.
Plenty of mappers out there and with the correct gui interface you can even map it yourself. Its not that difficult.
Leaves you more scope for tuning and you can switch maps easily.
Its all positive for me as why would you want to stick with an old ecu - calculators have more processing power than an L8 says it all really
Old 28-01-2016, 09:40 PM
Adam-M
Adam-M's Avatar
My Stihl strimmer revs faster than my yb but I still prefer the yb
Old 31-01-2016, 07:20 PM
cossynut2
cossynut2's Avatar
Question
I agree with you, my 450 bhp 2wd Saff runs an L8 ecu , has wasted spark ignition, plus new engine ,fans and fuel pump wiring looms, so it has a more advanced system than the original and does the job really well.
What big advantages would an Omex or similar ecu make?
Old 31-01-2016, 07:47 PM
steppy
steppy's Avatar
People get hung up on the fact of the omex is newer technology and you can map it yourself, it's also marginally cheaper, what they forget it's a cruder system on the 600 as it uses batch firing where the cosworth ran sequential as standard, to get sequential you have to use the 710 which is nearly double the cost of the 600 ecu. I personally believe a tried and tested route like the cosworth stuff which is known you can get great results from is the best, keep it simple
Old 02-02-2016, 06:35 PM
martysmartie
Lol, so a backward step then in terms of fuelling.
Exactly, it was F1 technology of the day, just because something is newer and has better better processing power does not necessarily make it better, for the most part it's just sales patter.
Martin
Old 02-02-2016, 07:00 PM
alo
alo's Avatar
Didn't the Ferrari f40 have two l8 ecus?
One of the most desirable and expensive cars going.
A little old but still good in my books
Old 02-02-2016, 07:37 PM
costina
costina's Avatar
Yes and tps for one is over 900 quid
Old 02-02-2016, 07:54 PM
Adam-M
Adam-M's Avatar
It's a pf01 in the f40 isn't it?
Old 02-02-2016, 08:18 PM
martysmartie
Yes, one to manage each bank of cylinders, another example is the Maserati Bi-turbo.
That is a TPS, but it depends on the model, the later ones were more like an L8.
Martin
The Youth.
27
25-02-2018 06:25 PM
Thanasis
21-01-2016 12:02 PM
hej-nee
19-01-2016 08:12 AM
Quick Reply: Cosworth ecu
