Fuel pump relay wiring
Hi I've got a 4x4 Saph which I've just had msd stage 2 conversion. On boost after a couple of days the rev counter started jumping around and then smoke started coming from the ignition barrel. Had a look and someone's wired in an extra wire from the ignition barrel to the ignition live on the yellow ecu relay next to the pump relay. This wire was totally melted. The normal black wire is still connected but gets no power with ignition on unless I run another wire directly from ignition barrel to the black ignition live on relay. I've bought an msd fuel pump rewire loom but I'm worried there's something wrong with the wiring to the old relay. What could cause this?
Any help appreciated
I think that's the result of a few alarms in the past. Gonna have to cut it all back and do it properly. Need to find out why the remote live that someone added in melted and why it's there in the first place :-(
The extra live joins the black wire going into the ecu relay. If I disconnect this wire the fuel pump won't prime so I'm guessing there's a break in the original remote live. Haven't had a chance to check it with a voltmeter yet
I'll try and have a look Friday when I'm off work. Is there any reason why that extra remote live would melt when the car was under hard load? Wouldn't have thought the pump demanding more power would have anything to do with the remote live
Haven't changed anything on the wiring after the stage 2 I had done by you back in February. The turbo died just before I got home so sent that off for repair and it took a few weeks then after getting it running again it lasted a day before it started playing up with this issue. I did think the extra load on the fuel pump for the increased power could of caused the wiring in it's poor condition to fail
Yeah that's what's confusing me. There's gotta be a break in the original remote live as it's still connected but doing nothing although it has a few dodgy joins in
cossie09
14-09-2015 04:21 PM
kosienutter
31
22-08-2015 09:55 AM
