Finis code for rear suspension bolts?
I need the part numbers/finis for various bolts on the back end of a saph 2WD.
-Trailing arm to beam (2 nuts & 2 bolts for each side)
-Bearing carrier to trailing arm (4 bolts each side)
-Beam mount to car (2 small and 1 large long bolt)
-Nuts, bolts & washers for diff to beam.
rog (28-01-2015)
rog (01-02-2015)
Cossy Mike (01-02-2015)
I think they are as follows but check with ford parts to confirm!
Outer trailing arm:
Bolt 6145599
Nut 1629583
Washer 6144431
Inner trailing arm:
Bolt 1644068
Nut 6078595
Washer? Can't find this but probably the same as the outer arm.
Let me know if I was correct!
Outer trailing arm:
Bolt 6145599
Nut 1629583
Washer 6144431
Inner trailing arm:
Bolt 1644068
Nut 6078595
Hi, many thanks for the info, 6145599 is NLA, tried a few places so must be true.
I thought the outer and inner trailing arm bolts were the same, I didn't have that one listed anywhere, will check.
As for the puma bolts, I looked at the diagram, I wasn't sure which ones to order, it only shows one bolt in the diagram I looked at, wasn't sure if I needed to double up and order two for each side or what????
Beam mount to car:
Long bolt 1627087
Washer1475686
Beam mount to car support plate:
Bolts 1451250
Washers 1436268
Diff mount to body 4 bolts 6165155
Two numbers for this not sure which ones 6130302 or 1436268
Diff mount to diff
Bolts 6561768
Washers 1436268
Can't find the bearing carrier bolts
Long bolt 1627087
Washer1475686
Bolts 1451250
Washers 1436268
Diff mount to diff
Bolts 6561768
Washers 1436268
rog (07-02-2015)
Ill check over the weekend Roj.
The inner and outer bolts are both the same spec, but they were colour coded blue and yellow.
I don't know the finis number but will look, my local ford man got them.
Even if you managed to get them new they come in a shitty dull silver passivate now anyway.
rog (07-02-2015)
Thanks a lot Mike, so four of these I assume, that's a great little trick to know!
Will get these ordered up now, I've already ordered the rest.
Tosh, thanks, it clarifies what I've ordered, and had no idea the bolts were different, mind you if you'd seen the beam I dismantled there was nothing left of the fixings to properly identify them. I have a very good used set of carrier bolts so will be ok for those at the moment, but might try and get some just to see if it's possible.
rog (07-02-2015)
track.focus'd
12-08-2015 05:53 PM
