oil pump priming
14-01-2014, 04:44 PM
oil pump priming
I have given my 2wd a freshen up and today filled with oil and primed using a flexi drive in the dizzy hole.
Turned clockwise and oil came faily quicky to the turbo feed, but what i did notice is the dizzy hole also filled with oil....
is this normal when doing this type of priming.....
Regards
14-01-2014, 06:09 PM
passionford pro
anything connected to the oil pressure side will get oil to it.
14-01-2014, 07:14 PM
OK anyone else got any thoughts
15-01-2014, 05:16 PM
Pretty sure the dizzy seals that hole once fitted?
15-01-2014, 07:33 PM
Thanks.....i am sure it will but to be honest did'nt quite expect alot of oil comming from there.
17-01-2014, 07:23 PM
Any more comments engine is being fitted next week, and want to make sure its right
Cheers guys
17-01-2014, 08:14 PM
Durham RSOC member
Yes you will have oil there and the dizzy seal will seal that once fitted.
17-01-2014, 08:42 PM
Thanks for the advice,
17-01-2014, 11:19 PM
Once you are ready to fire it up, pull the coil off and crank the engine over. That will build some oil pressure before you start the car.
18-01-2014, 08:34 AM
Thanks Paul...Yep was goin to do this...
Quote:
Originally Posted by
Paul_RS
DixieTheKid
11
06-06-2020 11:20 AM
155lee
27-10-2015 04:55 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Eigdoog
48
19-09-2015 11:03 AM
wheelwizardrefurbs
18-09-2015 08:59 PM
