if i turn from 2wd to 4wd do i change ABS?
im new to cossie stuff so bare with me
if i turn from 2wd to 4wd do i change ABS set up?
plan is turn my 2wd into 4wd…. i was going to run 2wd rear as thats what i have but run the 4wd up front on the 4wd hubs etc….
i have front and back 2wd ABS sensors (& ecu n loom)
i have front 4wd ABS sensors for hubs.
will - 2wd rear sensors n brakes work with 4wd front sensors n brakes on a 2wd ECU
thanks
thanks
the sensors are the same on all sierras yes
the sensors on the escort cos have a different plug
you deffo need a 4x4 abs ecu and you will need to check the wiring diagram in case its different aswell
The wiring is a stand alone loom and can be removed and replaced easy enough but im not certain you need to do this
steve
steve
steve
steve
Resident Wrestling Legend
there are extra wires and stuff to do different things
BUT
the 2wd system is better overall, although how it would work to prevent the wheels locking up is a bit vague
the 4wd system effectively "locks" all 4 wheels together when you are slowing down whereas the 2wd set up has effectively 3 different circuits of pulses regulating 2 different circuits of fluid
you should be ok, as it's a bit of a faf to change everything over, it's it's now working then leave it alone would be my vote
exactly right
BUT
BUT
but if i can run full 2wd ABS but using the 4x4 front brake calipers then thats exactly what il do?!!
it's only the sensors, if the new hubs have them still in place just leave them alone, they only break when you try to remove them
you don't need to fiddle with anything else, unplug the sensor from the inner chassis rail and plug the new ones back in again, job jobbed
my 4wd hubs have sensors in so if i take 2wd hubs off (unplugging 2wd sensors not removing from hub) n put the 4wd on (leaving them in their own hubs n just re-plugging them ones in) - just plug the sensors in and dont do anything else at all….? just want to double triple make sure…. thanks for clearing it up for me
how come u changed looms? above advice is to not change anything and keep it all 2wd ABS loom n ecu just plug the front sensors in wen hubs aare changed….
thats what i wanted to hear….one thing tho Richie im guessing u changed to 4wd hubs yes, and iv been told the sensors are all the same so again just a guess but u prob jus plugged in the 4wd ones. il start by doing that ;0)
thanks to all comments…. am also interested in who to see bout the bypass loom etc????
The Underdog
29
07-09-2015 09:49 PM
FlashRS
13
31-08-2015 06:02 PM
lockie
31-07-2015 10:03 PM
