Hi guys. I've just bought a new fuel pump loom for my saph. Bought from Matt lewis, but they forgot to put in the paperwork for installation. Can anyone help me out please.
Rich.
It should be pretty straight forward mate, the cables that conect to the battery and pump should be obvious then they'll be a trigger wire coming off the new relay which needs to be connect to the black and red wire from the orignal pump wiring.
Rich
hi guys thanks for the instructions. only problem i have now is the previous owner who had the car has decided to cut the original fuel pump loom i cant find where it goes. what side of the car does the original loom go down and where does it go from there?
cheers
Rich.
The original fuel pump wiring should come down the passenger side from the relays next to the ECU. Also isnt 25A fuse a bit too much , Im sure msd use 15A.
