4wd not working
Not entirely sane
Most likely to be the centre viscous knackered. Oil level will not affect it as it's a sealed unit. Though obviously oil level is important, the chain would run dry and not last long otherwise. It would likely exit the transfer casing as well.
Option 1:**Standard Exchange Transmission
From Ł450
This is a standard Cosworth transmission, fully overhauled with new bearings (including selector rails), late type fully coated syncro rings, selector forks, Hub sleeves, springs, guides & balls, circlips, selector pins, oil seals and o rings.
From Ł450
MrC just had it confirmed Ł300 for viscus,chain and bearings fitted .. This is from the link KSA-Cossie put on. E mail them from link mate for a price
cheers matey i'll find out now how much the whole shebang will be, everything on that list on the website.
are you taking just the gearbox down or the whole car and having them take it off overhaul it and bolt back on???
lockie
31-07-2015 10:03 PM
