3dr/2wd tca's
2wd Cosworth pinch bolts are tapered iirc,the castle nut type is for a 3 door and will be the same size thread from end to end.The 2wd and 4x4 use the same tca if that answers your question.Just not 3 door.
Would you care to explain what you are trying to do ?.If you have some 3 dr hubs and tca's swap the lot.They are adjustable are they not.
Rax,
Got a single tca from a buddy and wanted to order another and didn't want to get the wrong one, 2wd bolt hubs(saff) , interesting the 2wd/4x4 saff tca'sHow are the same, I'll just order a 4x4 one and will get the correct one then to be sure....
Have std 2.0 3dr tcas and they are bolt but look shorter than the cos ones...
Rob this will explain a bit more,I went through the same thing my self mate
https://passionford.com/forum/techni...trol-arms.html
Hope that sorts your problem.
Mark V8
13-09-2015 09:34 AM
