Saff cossie 4x4 play in turbo shaft
Received 1,042 Likes
How much play is in a standard saff cossie 4x4 turbo.I was fitting a K&N cone filter today and took the boost pipe off so i thought i would check the play in the saft.
I would say there is about 2/3 mil of play in it.I know modern turbo cars have a very slight bit of play but im a bit worried cause of the play in my the turbo shaft.I know when its running the oil will take up the play but i think mine has a bit to much play????
1 Post
Never good playing with shafts Glenn
Finally, known you for a while now and you've never had any worries about your faithful work horse
But as mentioned, don't worry about it. Knowing cossies, it'll bellow out major amounts of blue smoke before the turbo decides to deteriorate Remember how mine used to blow smoke after overun???
Anutternutter
21-08-2015 06:07 PM
mrmann
20-08-2015 11:24 PM
