wrc multi layered head gasket
hi all, graham goode have got the wrc multi layered head gasket, its in sale for 160quid inc. Is that a bargain? Looking for 450bhp. Is there anything in particular i should make sure this head gasket has? Cheers luke
Zee Germans are coming
if your gonna use a mulit layer than you must make sure the head and block are dead flat
other wise there is a very good chance it will fail
you will most likely need both re skimmed for this
escort cosworth gasket will be well up to the job of 450
If i use the escort cosworth gasket will the head have to be dead flat too? Cheers
Yer might aswell as i got greys oil cooler, big 500rad group a fuel pump waiting in my garage so might aswel save a bit more and get my head done and get new clutch. So how much will it cost to skim the head?
works out to be alot of money but worth it in the long run
depends on your budget
Cheers mate so if i go for group a head gasket i wont need to take engine out, and i wouldnt need the head skimmed either! What feature should i look for when buying the group a gasket?just one that says escort cosworth group a head gasket???? Cheers
give matt lewis a bell he will suply you with what you need at got prices too
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
