205 or 215 tyres
Old 16-05-2008, 03:37 PM
lozi
My Cossie Ate My Money
lozi's Avatar
Default 205 or 215 tyres
I have got soft spoke rs7's on my saph 4x4, i am going to get 4 new tyres soon and the current tyres are 215's
i have noticed 205's are abit cheaper, is there any reason why not to get 205's and stick with 215's?
thanks
Old 16-05-2008, 03:39 PM
cossie604
cossie604's Avatar
reason being they look too skinny....stick with the 215's ya tight begger
Tried www.mytyres.co.uk at all?
Old 16-05-2008, 03:40 PM
Dan
Dan's Avatar
215's are fine on the front mate, for even better on the grip, dependent on the wheel you'd be better off going for 235's on the back!
Old 16-05-2008, 03:58 PM
lozi
lozi's Avatar
i use blackcircles.com
they are not alot skinnier though are they? i do get abit of rubbing on the front as well and i thought 205's would maybe sort that out?
Old 16-05-2008, 04:00 PM
Dan
Dan's Avatar
205's will sort that out mate, for 215's you need to slightly roll your front arches
For 235's on the rear you need to do nothing at all!
Old 16-05-2008, 04:18 PM
lozi
lozi's Avatar
i prefer to have same tyres all round, wouldnt 235's look abit strange?
Old 16-05-2008, 04:29 PM
cossiegreg1
cossiegreg1's Avatar
205 and 7.5j wheels make the tire look stretched.
different brands of tire are better than others. i had falken 205 on 7 spokes and they were stretched. but i seen 205 toyo tires on 7 spokes and they looked fine.
Old 16-05-2008, 04:31 PM
lozi
lozi's Avatar
does the car still handle alright on 205's?
Old 16-05-2008, 04:41 PM
Nash
Cake lover!
Nash's Avatar
215 for yours, why try and save a few quid when it will reduce grip. You cant go 235 even if wanted to as 4x4's need same size tyres front and back or it mess's up the VC.
Old 16-05-2008, 04:54 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
i was just going to say,its 4x4, dont run different size tyres, unless the rolling radius is the same.....
215s rub a tad on 8inch wheels, 8x18, et35.
but not on my old 7.5s......
205 will be to skiny imo...
Old 16-05-2008, 05:06 PM
cossie604
cossie604's Avatar
My 3dr runs 245's on the arse...fills out the arches well
Old 16-05-2008, 06:26 PM
h5kcd
h5kcd's Avatar
im on 215 40 17 prada 2 on softspokes and they are fine on my 2wd saff
Old 16-05-2008, 08:25 PM
Mr C
Mr C's Avatar
215s on a car that size, match the rolling radius front to rear and go as wide as you can on the rear staying within the above radius.
Old 16-05-2008, 10:46 PM
lozi
lozi's Avatar
i will stick to 215's if it will affect the handling i just thought it may look abit better and save me a few quid!
Old 17-05-2008, 09:06 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Dan,
that does depend on tyre choice and offset. As i found out 235/40/17 toyo 888 needs arch rolling at on my saff. Main reason being the 235 is actually 242 wide. Awesome for grip, but not for the arch lol
Old 17-05-2008, 11:19 AM
joffy
SLOW LEARNER
joffy's Avatar
ive got 205 toyo 888rs on mine now, did have 215's when i had yokos but the toyo looks alot bigger??
Old 17-05-2008, 02:21 PM
Nash
Cake lover!
Nash's Avatar
R888's are a different kettle of fish, as stated by Rich they are actually wider that is written on the sidewall.
Old 17-05-2008, 03:32 PM
cossiegreg1
as said here ^^^^
Old 17-05-2008, 08:12 PM
CossieRich
CossieRich's Avatar
the 205 measures 212 wide so pretty much as wide as a normal 215 tyre.
Old 17-05-2008, 09:20 PM
Nash
Cake lover!
Nash's Avatar
as said here ^^^^
I had a 205 T1Rs on a 7.5 rim and looked stretched over. Then i have seen R888's in 205 on a 8 rim and they looked fine. I think it comes down to they style of the tyre not the make which are aimed at totally different people.
Old 18-05-2008, 05:37 AM
It would have been a LOT easier if FORD had just used decent sized tyres to start with!!
Old 18-05-2008, 08:32 AM
CossieRich
CossieRich's Avatar
you are quite correct Nash. My new comp wheels are 8 inch wide and i use the 205 888 at teh front which look fine and the 235 at the rear which also look fine but required arch mods. Not Sure why toyo dont use the correct size on their adverts or sidewall lol
Old 18-05-2008, 11:54 AM
Nash
Cake lover!
Nash's Avatar
Which wasnt possible, the car would have needed larger archs. The car would have needed to use different panels/ rear end to get larger inner archs over the normal Saph shell, which in turn would have put costs up.
Old 18-05-2008, 12:36 PM
Not such a cost in comparison to the engine developemnt, at least they could of got that right first time unlike the engine!!
Mark RS
05-03-2021 06:08 PM
tankybaby66
06-02-2016 02:24 PM
07-10-2015 12:56 PM
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
Quick Reply: 205 or 215 tyres
