Starter motor only works when cold
Old 05-04-2008, 02:03 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Starter motor only works when cold
Also posted in the tech help section. If I stop the car for a few minutes, the starter won't spin until the car has cooled down somewhat.
I'm sure someone here posted about this a year ago or so, but can't remember the outcome.
And don't get me started on the "search" function here...
Old 05-04-2008, 03:04 PM
boXXer
GASH!
boXXer's Avatar
pretty sure its a knackered starter/solenoid. When the car is cold, it has less compression than when fully warmed, so its harder for the starter to spin over. i think
Old 05-04-2008, 03:09 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Yep been doing lots of reading, looks like solenoid sticking when hot. Luckily I have a spare starter kicking around, just hadn't planned on lying on the dirt fixing my car today!
Old 05-04-2008, 03:19 PM
MARCOSWORTH
MARCOSWORTH's Avatar
Just put a hammer in the car mate
Old 05-04-2008, 03:36 PM
TurboShed
Cossiemodo
TurboShed's Avatar
LoL, don't worry, I've gotta go out in a bit, gonna take the spare starter, and a hammer, as a survival kit. Just really really don't want to get mucky today, life is too short!
Old 05-04-2008, 07:17 PM
Wardy257
Wardy257's Avatar
Volt drop it all and you will find the problem!!!
Old 05-04-2008, 10:36 PM
tricky 1
tricky 1's Avatar
had exactly this problem with an old astra years ago.changed the starter motor. when it had the problem if you rocked it to & fro in gear, it would start every time.
Old 06-04-2008, 12:24 AM
jon@work
jon@work's Avatar
I'd check the wiring to the solenoid first - I bet there's a corroded/dodgy joint in there
The Youth.
23-08-2015 08:53 PM
The Enigma
13
20-08-2015 09:38 PM
Ben26
Ford Focus Diesel
18-08-2015 03:42 PM
Shows & Track Days
15-08-2015 06:25 AM
Quick Reply: Starter motor only works when cold
