strange smoke
Old 23-03-2008, 10:35 PM
bigryrs
RSHoleinator
bigryrs's Avatar
Default strange smoke
might sound daft but i was giving my 4x4 saph some beans the other day round a very sharp corner in second gear and when i straightened up there was a puff of reek that came out the drivers side bonnet vent its never happened before but then again i never cane it any help would be great thanks in advance
Old 23-03-2008, 10:36 PM
KSA-Cossie
KSA-Cossie's Avatar
What colour m8 ?
Old 24-03-2008, 09:57 AM
bigryrs
RSHoleinator
bigryrs's Avatar
Originally Posted by KSA-Cossie
What colour m8 ?
not sure mate it was just a quick puff but this is a severe bend and you can only go round it at about 30mph max so its the only time its ever done it
Old 24-03-2008, 10:25 AM
indycos
helooooo!!!
indycos's Avatar
well the drivers side bonnet vent is where the turbo is located so theres a hint as to what it might have been something to do with?
Old 24-03-2008, 10:56 AM
AndyPen
AndyPen's Avatar
Gary from Portsmouth had fuel spray over onto the turbo somehow and the smoke came out of that vent... as seen at Ford Fair. Check those fuel seals mate - just in case, I know they are on the other side but the pressures are high so it might squirt over like his did. Cant think of much else on the turbo side as said???
Old 24-03-2008, 03:07 PM
bigryrs
RSHoleinator
bigryrs's Avatar
now that you say that mate ive noticed a whiff of petrol now and then do you think thats what it could be it cant be the turbo its a genuine ford t34 not recon and its done like 1k miles since it was fitted il give it a check when i get home cheers
Old 24-03-2008, 03:08 PM
bigryrs
RSHoleinator
bigryrs's Avatar
cant be the turbo its a proper ford t34 and its done hardly any miles since fitted about a year ago it doesnt smoke on start up theres never any reek just that one time and thats it
Old 24-03-2008, 03:34 PM
mechanic28
mechanic28's Avatar
proper ford one????
Old 24-03-2008, 07:31 PM
bigryrs
RSHoleinator
bigryrs's Avatar
Originally Posted by mechanic28
proper ford one????
yeah not a cheapo shitey one from china for 100 quid lol
Old 24-03-2008, 09:33 PM
AndyPen
AndyPen's Avatar
I think from recollection Gary said that the fuel came from the fuel rail and squirted over onto the turbo. I'll ask him if I get the chance.
Old 24-03-2008, 09:36 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Probably just a bit of oil dripping onto a hot component, ie. turbo or manifold. The very sharp bend, a few drops of oil from somewhere, no major surprise, I've noticed the same myself once or twice.
Old 24-03-2008, 10:01 PM
bigryrs
RSHoleinator
bigryrs's Avatar
ok cheers mate
Old 25-03-2008, 07:40 PM
Twellsie
Twellsie's Avatar
what oil breather setup are you running?
Old 25-03-2008, 09:20 PM
bigryrs
RSHoleinator
bigryrs's Avatar
standard mate
Old 25-03-2008, 11:11 PM
AndyPen
AndyPen's Avatar
Didn't get to chat to Gary but yes his was fuel somehow. Fuel rail may have worked loose or seals just perished on the injectors. No pipes appeared loose from what he told me at the time. All worth checking imo - if only for piece of mind eh?
Old 26-03-2008, 06:49 AM
bigryrs
RSHoleinator
bigryrs's Avatar
yeah defo mate im getting back onshore today so il be looking at it when im finished with the bird lol cheers for the help
Old 26-03-2008, 08:13 AM
boost mad
boost mad's Avatar
do you have a dump valve ?
back when i had my first cossie i was giving it some right foot action then when i backed off and the dumpvalve went off it misted oil everywhere. Looked like a fine smoke to start with, then realised the oil that cam out of the valve hit the turbo and burnt, hence the smoke
this was obviously without a cold side conversion !
Old 26-03-2008, 05:47 PM
bigryrs
RSHoleinator
bigryrs's Avatar
nah mate the dump valve is on the other side opposite side from the turbo
Old 26-03-2008, 06:58 PM
boost mad
boost mad's Avatar
that rules that one out then
Old 26-03-2008, 08:17 PM
saff cosworth
saff cosworth's Avatar
it could be the oil return pipe under the turbo, the gasket there has a habit of failing at times...just somthing to check....
Steve Escos
01-10-2015 06:57 AM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
Brickhouse
21-09-2015 04:31 PM
Brickhouse
21-09-2015 11:00 AM
Quick Reply: strange smoke
