another fuel pump question
Old 06-03-2008, 10:20 AM
stevecossy
stevecossy's Avatar
Default another fuel pump question
When rewiring the pump i know to use the 2 orig wires from pump as switching for the relay, but do i plug the earth wire into the earth on relay and take a new earth wire from the pump to a good new earth point on chassis?
I think this is how most have done theirs but just have that doubt i not remember right Doh.
Also i will be taking a live direct from battery to relay in boot and from relay to pump etc.
Cheers again fellas. steve
Old 06-03-2008, 12:11 PM
mechanic28
mechanic28's Avatar
on your new relay you use your original earth for the switching side on term 85 or 86 cant remember which,and then as you say use a new earth from the pump to the chassis i used the rear anti roll bar!
Old 06-03-2008, 01:55 PM
I would use a new earth and live, straight from the battery, the chassis where it is exposed is going to build up a high resistance.
14/030 wire is more than suffecient for this, use the live after the cut out, so keeping that in circuit.
If you look behind the rear seat on the metalwork near the top there is a 8mm hole that is just right for securing a relay holder to, you can then take the relay out as an added security measure, if at shows etc.
Old 07-03-2008, 04:53 AM
stevecossy
stevecossy's Avatar
Nice 1 thanks alot guys, hope to do it at weekend.
Regards steve
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
15
07-10-2015 03:43 PM
Quick Reply: another fuel pump question
